Version 33.2.1 adds support for a keep alive message on the Netlogin RADIUS server. This checks for RADIUS server reachability in order to limit unnecessary re-authentication.
All platforms.
The following new commands support this feature:
# show radius
RADIUS Default State: disabled
RADIUS Default Timeout: 3 seconds
RADIUS Algorithm: standard
RADIUS Retries: 3
RADIUS port bounce VSA: off
RADIUS dynamic-authorization: disabled
RADIUS TLS TCP Timeout: default
RADIUS TLS OCSP: off
RADIUS TLS OCSP Attributes:
Nonce : off
Signer ocsp-nocheck : off
Override Server URL : none
Switch Management RADIUS: disabled *
Switch Management RADIUS server connect time out: 3 seconds *
Switch Management RADIUS Accounting: disabled *
Switch Management RADIUS Accounting server connect time out: 3 seconds
Netlogin RADIUS: enabled
Netlogin RADIUS server connect time out: 3 seconds *
Netlogin RADIUS server keep alive: on
Netlogin RADIUS server keep alive interval: 60 seconds
Netlogin RADIUS server's last known reachability status: unreachable
Netlogin RADIUS Accounting: disabled *
Netlogin RADIUS Accounting server connect time out: 3 seconds
Primary Netlogin RADIUS server: Status is Active
host name :
IP address : 1.2.3.4
Server IP Port: 1812
Protocol : UDP
Client address: 10.127.2.33 (VR-Mgmt)
Retries : 3 *
Timeout : 3 *
shared secret : #$S4/Mj804b1yid8IYgRCNF2qdlGKD+A==
Access Requests : 157 Access Accepts : 0
Access Rejects : 0 Access Challenges : 0
Access Retransmits: 117 Client timeouts : 156
Bad authenticators: 0 Unknown types : 0
Round Trip Time : 0
Legend: An asterisk (*) indicates a global value is in use.
