Switch Engine v33.4.1 Release Notes
> Extreme Switch Security Assessment
May 01, 2025
Abstract
Preface
New Hardware Supported in Switch Engine 33.4.1
Security Information
Linux Kernel
OpenSSL Version
Upgrading Switch Engine
Newly Purchased Switches Require Software Upgrade
Default Switch Engine Settings
Switch Engine Image File Names
New and Corrected Features in Switch Engine 33.4.1
7520 and 7720 Transparent Clock Support
BFD for PIM Support
Configurable Anycast RP Register Suppression Timer
Enhanced RADIUS Server Handling for dot1x EAP Authentication
IPv6 Rule - Match Condition Enhancement in ACL Style Policy
Lower the Minimum MTU Configuration to 1200 Bytes
Message-Authenticator Attribute in RADIUS Authentication Packets
New Device Type in Instant Port
Reference Identifier for RADIUS TLS
STP BPDU BridgeID Extension Support
TLS Certificate Download Using VR-Default and User-Defined VRs
VLAN Name-Based Configuration in RADIUS and TACACS
ExtremeCloud IQ Agent Support
Extreme Hardware/Software Compatibility and Recommendation Matrices
Compatibility with Extreme Management Center
Supported MIBs
Tested Third-Party Products
Limits
Limits Overview
Base License Limits
Premier License Limits
Notes for Limits Tables
Open Issues, Known Behaviors, and Resolved Issues
Open Issues
Known Behaviors
Resolved Issues in Switch Engine 33.4.1
DoS Attack Assessment
Tools used to assess DoS attack vulnerability:
Network Mapper (NMAP)
ICMP Attack Assessment
Tools used to assess ICMP attack vulnerability:
SSPing
Twinge
Nuke
WinFreeze
Port Scan Assessment
Tools used to assess port scan assessment:
Nessus
