The flood rate-limit feature includes configurable burst tolerance levels and optional out-of-profile actions. This allows operators to fine-tune packet buffer handling for broadcast, multicast, and unknown-destination MAC traffic on a per-port basis.
Issue: The flood rate-limit feature enforces a fixed buffer bucket size for controlling broadcast, multicast, and unknown-destination MAC traffic. Network administrators cannot customize burst behavior or define actions when traffic exceeds the rate limit, making it difficult to balance strict rate enforcement with brief traffic spikes in bursty network environments.
Resolution: The flood rate-limit feature includes two enhancements: (1) a configurable burst-tolerance parameter that controls buffer handling at different tolerance levels, and (2) optional out-actions that specify actions when traffic exceeds the configured rate limit, such as logging events, generating SNMP traps, or disabling the port.
Key Capabilities:
Configure flood rate-limit with burst tolerance and out-of-profile actions:
configure ports [<port_list> | <port_group>] rate-limit flood [broadcast | multicast | unknown-destmac] <pps> { burst-tolerance [default | low | medium | high] } {out-actions [{log} {trap} {disable-port}] }
Parameters
<pps> — Rate limit in packets per secondburst-tolerance — Buffer size control: default uses existing behavior, low applies strict suppression, medium applies moderate tolerance, high applies permissive toleranceout-actions — Actions when traffic exceeds the limit: log logs the event, trap sends an SNMP trap, disable-port disables the portExample Configuration
configure ports 1 rate-limit flood broadcast 2000 burst-tolerance low out-actions log
This configuration limits broadcast traffic on port 1 to 2000 packets per second with low burst tolerance and logs any rate-limit violations.
View the configured burst tolerance and rate-limit status:
show port 1 information detail
Sample Output
Port: 1 Virtual-router: None Type: UTP ... Broadcast Rate: 2000 packets-per-second Burst Tolerance: Low Multicast Rate: No-limit Unknown Dest Mac Rate: No-limit ...
All platforms.
