Premier License Limits
The following table shows supported limits for features in the Premier License.
Table 1. Supported Limits for the Premier License
MetricProductLimit
Anycast RP Using PIM—maximum number of IPv4 Anycast RP set per VR.All platforms32
Anycast RP Using PIM—maximum number of IPv6 Anycast RP set per VR.All platforms32
Anycast RP Using PIM—RP peers per Anycast RP set.All platforms10
BGP (aggregates)—maximum number of BGP aggregates. 5120, 5320, 5420, 5520, 5720, 7520, 7720256
BGP (networks)—maximum number of BGP networks. 5120, 5320, 5420, 5520, 5720, 7520, 77201,024
BGP (peers)—maximum number of BGP peers.
Note: With default keepalive and hold timers.
Note: Each BGPv4/BGPv6 peer handles a maximum of 50 routes.
Note: ECMP should not be enabled for BGP.
5120, 5320, 5420, 5520, 5720, 7520, 7720300
BGP (peer groups)—maximum number of BGP peer groups. 5120, 5320, 5420, 5520, 5720, 7520, 772064
BGP (policy entries)—maximum number of BGP policy entries per route policy. 5120, 5320, 5420, 5520, 5720, 7520, 7720256
BGP (policy statements)—maximum number of BGP policy statements per route policy. 5120, 5420, 5520, 5720, 7520, 77201,024
5320820
BGP (multicast address-family routes)—maximum number of multicast address-family routes. 5520, 5720MW13,000
5720-MXW20,000
7520, 772025,000
5320 48-port, 542012,000
5320-16P-4XE, 5320 24-port except XT8,000
5320-24T-4X-XT, 5320-16P-2MXT-2X992
512064
BGP (unicast address-family routes)—maximum number of unicast address-family routes. 5520, 5720MW (at default)13,000
7520, 7720 (at default)25,000
5720-MXW (at default)20,000
512064
5720-MW (with ALPM enabled)163,000
5720-MXW (with ALPM enabled)288,000
5520 (with ALPM enabled)80,000
BGP (non-unique routes)—maximum number of non-unique BGP routes. 7520, 772075,000
5320 48-port, 5420, 5520, 5720-MW36,000
5720-MXW60,000
5320-16P-4XE, 5320 24-port except XT24,000
5120192
5320-24T-4X-XT, 5320-16P-2MXT-2X2,700
BGP ECMP—maximum number of equal cost paths per multipath for BGP and BGPv6. 5120, 5320, 5420, 5520, 7520, 77208
572064
BGPv6 (unicast address-family routes)—maximum number of unicast address family routes. 5320 48-port, 5420, 5520, 5720-MW (at default)6,000
5720-MW (with ALPM enabled)107,000
5720-MXW, 7520, 7720 (at default)10,000
5720-MXW (with ALPM enabled)213,000
5320-16P-4XE, 5320 24-port except XT4,000
5320-24T-4X-XT, 5320-16P-2MXT-2X496
512064
5520 (with ALPM enabled)40,000
BGPv6 (non-unique routes)—maximum number of non-unique BGP routes. 5420, 5520, 5720-MW18,000
5720-MXW, 7520, 772030,000
5320 (except 5320-24T-4X-XT, 5320-16P-2MXT-2X)14,000
5320-24T-4X-XT, 5320-16P-2MXT-2X1,488
5120192
EVPN EVI instances—maximum number of EVI instances.All platforms, except 4120 and 51201,024
IS-IS adjacencies—maximum number of supported IS-IS adjacencies.All platforms128
IS-IS ECMP—maximum number of equal cost paths per multipath for IS-IS.All platforms2, 4, or 8
IS-IS interfaces—maximum number of interfaces that can support IS-IS.All platforms255
IS-IS routers in an area—recommended maximum number of IS-IS routers in an area.All platforms256
IS-IS route origination—recommended maximum number of routes that can be originated by an IS-IS node.All platforms20,000
IS-IS IPv4 L1 routes in an L1 router—recommended maximum number of IS-IS Level 1 routes in a Level 1 IS-IS router.All platforms25,000
IS-IS IPv4 L2 routes—recommended maximum number of IS-IS Level 2 routes.All platforms25,000
IS-IS IPv4 L1 routes in an L1/L2 router—recommended maximum number of IS-IS Level 1 routes in an L1/L2 IS-IS router.All platforms20,000
IS-IS IPv6 L1 routes in an L1 router—recommended maximum number of IS-IS Level 1 routes in a Level 1 IS-IS router.All platforms10,000
IS-IS IPv6 L2 routes—recommended maximum number of IS-IS Level 2 routes.All platforms10,000
IS-IS IPv6 L1 routes in an L1/L2 router—recommended maximum number of IS-IS Level 1 routes in a L1/l2 router.All platforms10,000
IS-IS IPv4/IPv6 L1 routes in an L1 router—recommended maximum number of IS-IS Level 1 routes in a Level 1 IS-IS router. The numbers documented are based on 50% IPv4 routes and 50% IPv6 routes.All platforms20,000
IS-IS IPv4/IPv6 L2 routes in an L2 router—recommended maximum number of IS-IS Level 2 routes in a Level 2 IS-IS router. The numbers documented are based on 50% IPv4 routes and 50% IPv6 routes.All platforms20,000
IS-IS IPv4/IPv6 L1 routes in an L1/L2 router—recommended maximum number of IS-IS Level 1 routes in a Level 1/Level2 IS-IS router. The numbers documented are based on 50% IPv4 routes and 50% IPv6 routes.All platforms20,000
L2 VPN: VCCV (pseudowire Virtual Circuit Connectivity Verification) VPNs per switch—maximum number of VCCV enabled VPLS VPNs. 5520, 7520, 772016
5120, 5320, 5420, 5720N/A
L2 VPN: VPLS MAC addresses—maximum number of MAC addresses learned by a switch. 552064,000
7520, 7720140,000
L2 VPN: VPLS VPNs—maximum number of VPLS virtual private networks per switch. 5520, 7520, 77201,023
L2 VPN: VPLS peers—maximum number of VPLS peers per VPLS instance. 5520, 7520, 772064
L2 VPN: LDP pseudowires—maximum number of pseudowires per switch. 55203,500
7520, 77207,000
L2 VPN: static pseudowires—maximum number of static pseudowires per switch. 55203,500
7520, 77207,000
L2 VPN: Virtual Private Wire Service (VPWS) VPNs—maximum number of virtual private networks per switch. 55201,023
7520, 77204,090
MPLS RSVP-TE interfaces—maximum number of interfaces. 5520, 7520, 772032
MPLS RSVP-TE ingress LSPs—maximum number of ingress LSPs. 5520, 7520, 77202,000
MPLS RSVP-TE egress LSPs—maximum number of egress LSPs. 5520, 7520, 77202,000
MPLS RSVP-TE transit LSPs—maximum number of transit LSPs. 5520, 7520, 77204,000
MPLS RSVP-TE paths—maximum number of paths. 55201,000
7520, 77202,000
MPLS RSVP-TE profiles—maximum number of profiles. 55201,000
7520, 77202,000
MPLS RSVP-TE EROs—maximum number of EROs per path. 5520, 7520, 772064
MPLS LDP peers—maximum number of MPLS LDP peers per switch. 5520, 7520, 7720128
MPLS LDP adjacencies—maximum number of MPLS LDP adjacencies per switch. 5520, 7520, 772064
MPLS LDP ingress LSPs—maximum number of MPLS LSPs that can originate from a switch. 5520, 7520, 77202,048
MPLS LDP-enabled interfaces—maximum number of MPLS LDP configured interfaces per switch. 5520, 7520, 7720128
MPLS LDP transit LSPs—maximum number of MPLS transit LSPs per switch. 55203,500
7520, 77204,000
MPLS LDP egress LSPs—maximum number of MPLS egress LSPs that can terminate on a switch. 55203,500
7520, 77204,000
MPLS static egress LSPs—maximum number of static egress LSPs. 55203,500
7520, 77208,000
MPLS static ingress LSPs—maximum number of static ingress LSPs. 55203,500
7520, 77204,000
MPLS static transit LSPs—maximum number of static transit LSPs 55203,500
7520, 77204,000
MSDP active peers—maximum number of active MSDP peers. 512016
MSDP SA cache entries—maximum number of entries in SA cache. 5120192
5320, 5420F6,000
5420M8,000
5520, 5720, 7520, 772014,000
MSDP maximum mesh groups—maximum number of MSDP mesh groups.All platforms16
OSPFv2/v3 ECMP—maximum number of equal cost multipath OSPFv2 and OSPFv3. 5120, 5320, 5420, 55208
572064
OSPFv2 areas—as an ABR, how many OSPF areas are supported within the same switch.All platforms8
OSPFv2 external routes—recommended maximum number of external routes contained in an OSPF LSDB. 512064
552080,000
5720-MX150,000
5720-MXW290,000
7520, 7720320,000
5320 (except 5320-16P-2MXT-2X, 5320-24T-4X-XT), 54204,000
5320-16P-2MXT-2X992
5320-24T-4X-XT500
OSPFv2 inter- or intra-area routes—recommended maximum number of inter- or intra-area routes contained in an OSPF LSDB with one ABR in OSPF domain.512064
552080,000
5720-MW150,000
5720-MXW290,000
7520, 7720320,000
5320 (except 5320-16P-2MXT-2X, 5320-24T-4X-XT), 54201,600
5320-16P-2MXT-2X992
5320-24T-4X-XT500
OSPFv2 combined inter-area and external routes—recommended maximum number of combined inter-area and external routes contained in an OSPF LSDB.512064
552080,000
5720-MW150,000
5720-MXW290,000
7520, 7720320,000
5320-16P-2MXT-2X992
5320-24T-4X-XT500
OSPFv2 inter-vr or leaking routes—recommended maximum number of inter-vr routes contained in an OSPF LSDB.​​​ 5420, 5520, 5720, 7520, 77202,000
5320 (5320-16P-2MXT-2X, 5320-24T-4X-XT)1,600
512064
OSPFv2 interfaces—recommended maximum number of OSPF interfaces on a switch (active interfaces only). 5420, 5520, 5720, 7520, 7720400
5320320
512064
OSPFv2 links—maximum number of links in the router LSA. 5420, 5520, 5720, 7520, 7720400
5320320
512064
OSPFv2 neighbors—maximum number of supported OSPF adjacencies. 5420, 5520, 5720, 7520, 7720128
532096
512064
OSPFv2 routers in a single area—recommended maximum number of routers in a single OSPF area. 5420, 552050
5720, 7520, 7720100
5120, 532040
OSPFv2 virtual links—maximum number of supported OSPF virtual links. 5420, 5520, 5720, 7520, 772032
5120, 532025
OSPFv3 areas—as an ABR, the maximum number of supported OSPFv3 areas. 5420, 552016
5720, 7520, 7720100
5120, 532012
OSPFv3 external routes—recommended maximum number of external routes. 552040,000
5720-MW70,000
5720-MXW150,000
7520, 7720260,000
5120, 5320 (except 5320-16P-2MXT-2X, 5320-24T-4X-XT), 5720-MW7,500
54206,000
5320-16P-2MXT-2X496
5320-24T-4X-XT300
512064
OSPFv3 inter- or intra-area routes—recommended maximum number of inter- or intra-area routes. 552040,000
5720-MW70,000
5720-MXW150,000
7520, 7720260,000
5320 (except 5320-16P-2MXT-2X, 5320-24T-4X-XT)4,000
54206,000
5320-16P-2MXT-2X496
5320-24T-4X-XT300
512064
OSPFv3 combined inter-area and external routes—recommended maximum number of combined inter-area and external routes.552040,000
5720-MW70,000
5720-MXW150,000
7520, 7720260,000
54206,000
5320-16P-2MXT-2X496
5320-24T-4X-XT300
512064
OSPFv3 interfaces—maximum number of OSPFv3 interfaces (active interfaces only). 5420, 5520, 5720, 7520, 7720256
5320192
512064
OSPFv3 neighbors—maximum number of OSPFv3 neighbors. 5420, 5520, 5720, 7520, 772064
5120, 532048
OSPFv3 virtual links—maximum number of OSPFv3 virtual links supported. All platforms except 4120 and 422016
PIM IPv4 (maximum interfaces)—maximum number of PIM active interfaces. 5320, 5420, 5520, 5720, 7520, 7720255
512060
PIM IPv4 Limits—maximum number of multicast groups per dynamic rendezvous point. 5120, 5320, 5420, 5520, 5720, 7520, 7720180
PIM IPv4 Limits—maximum number of multicast groups per static rendezvous point. 5320, 5420, 5520, 5720, 7520, 77203,000 (depends on policy file limits)
5120192
PIM IPv4 Limits—maximum number of multicast sources per group. 5320, 5420, 5520, 5720, 7520, 77205,000
5120192
PIM IPv4 Limits—maximum number of dynamic rendezvous points per multicast group. 5320, 5420, 5520, 5720, 7520, 7720145
512032
PIM IPv4 Limits—static rendezvous points. 5120, 5320, 5420, 5520, 5720, 7520, 772032
PIM IPv6 (maximum interfaces)—maximum number of PIM active interfaces. 5320, 5420, 5520, 5720, 7520, 7720255
512030
PIM IPv6 limits—maximum number of multicast sources per group.5320, 5420, 5520, 5720, 7520, 77201,750
512070
PIM IPv6 limits—maximum number of multicast groups per dynamic rendezvous point.5120, 5320, 5420, 5520, 5720, 7520, 772070
PIM IPv6 limits—maximum number of multicast groups per static rendezvous point.5320, 5420, 5520, 5720, 7520, 77203,000 (depends on policy file limits)
512070
PIM IPv6 limits—maximum number of multicast groups per dynamic rendezvous points per multicast group.5320, 5420, 5520, 5720, 7520, 772064
512020
PIM IPv6 limits—maximum number of secondary addresses per interface5320, 5420, 5520, 5720, 7520, 772070
512030
PIM IPv6 limits—maximum number of static rendezvous points.5120, 5320, 5420, 5520, 5720, 7520, 772032
PTP/1588v2 Clock Ports 7520-48Y, 7720-32C32 for boundary clock
PTP/1588v2 Clock Instances 5320-16P-2MXT, 5420, 5520, 5720, 7520-48Y, 77201 transparent clock
7520-48Y, 7720-32C1 boundary clock
PTP/1588v2 Unicast Static Masters7520-48Y, 7720-32C10 entries per Slave clock type
