Configure the Management Interface from the Console Port
Obtain a laptop with PuTTY, TeraTerm, or another terminal emulator installed on it. If the laptop does not support RS232 interface, then obtain a USB to RS232 converter cable, which then connects to the RJ45-DB9F cable.
You also need the following information:
  • Admin password
  • Host attributes settings
  • Time settings
  • DNS settings
  • Data plane settings
You can configure the 1130C appliance from the appliance console port if you have physical access to it. Configuration is asynchronous, but you can see the boot up process.
The console port is on the appliance's front panel. See Front and Back Panel Information.
  1. Connect the laptop serial port to the console port.
    If the laptop does not support the RS232 interface, then obtain a USB to RS232 converter cable, which then connects to the RJ45-DB9F cable.
  2. Connect to the serial port connection with a terminal emulator.
    Ensure that your serial connection is set properly:
    • 115200 baud
    • 8 data bits
    • 1 stop bit
    • Parity none
    • Flow control none
  3. Enter the password in the console session when prompted.
    The default user is admin and the default password is abc123.
  4. Enter the following information when prompted by the configuration script:
    • Admin Password
    • Host Attributes Settings
    • Time Settings
    • DNS Settings
    • Data Plane Settings
  5. Type Yes at the end of each session and move to the next session.
    If you type No, the session configuration options are repeated.
  6. Press Enter.
    The Appliance Post Installation Configuration Menu opens after the last session is applied.
  7. Do one of the following:
    Enter A to apply settings and exit.
    Enter a number to repeat the setup.
  8. Connect to a port that had management access enabled during the CLI Wizard Setup.
  9. Open a web browser and enter https://Your_Mgmt_Ipaddress:5825 into the address bar.
    The Universal Compute Platform login screen opens.
  10. Enter admin and the credentials that were created when setting up the installation wizard.
    An installation wizard is available to help configure the 1130C for new deployments. For more information, see ExtremeCloud Edge – Self-Orchestration Deployment Guide for Universal Compute Platform.
