VE6120/VE6125 Virtual Appliances Installation Guide VMware® Platform
Virtual Appliance Configuration
> Manage the Flash Memory
Extreme Networks, Inc. October 01, 2026
Abstract
Preface
New in This Guide
Virtual Appliance Deployment
Deployment Requirements
Connectivity Requirements
Download a VE6120/VE6125 Image
Log into the vSphere Client
Install and Deploy the Virtual Appliance Image
Access the Virtual Appliance Console
Configure the VE6120/VE6125 Using the Basic Configuration Wizard
Set up the VE6120/VE6125 Appliance Using the Basic Configuration Wizard
Upgrade the VE6120/VE6125 Software
Perform a Backup
Copy Backup
Set Up the Virtual Appliance to Accept USB Flash Drives
Remove the Flash Drive
Generate and Install the Activation Package
Subscription License
Configure vSwitches for the Virtual Appliance
Create a New Virtual Switch or Port Group on the ESXi Server
Configuring the Virtual Switch for Promiscuous Connections
Configure the Virtual Switch for Jumbo Frames Support
Configure a Virtual Machine to Gain Networking Performance
Shut Down and Restart a Virtual Machine
Shut Down and Restart a Virtual Machine Using the Graphical User Interface (GUI)
Shut Down and Restart a Virtual Machine on a ESXi Server
Follow these steps to manage flash memory:
Log into the ExtremeCloud IQ Controller using your credentials.
In the left pane, from the
Administration
drop-down, select
System > Maintenance > External Flash
option.
Use the
Mount/Unmount
options to mount and unmount flash memory respectively.
Flash Memory Maintenance Window
