The following table defines parameters for the radius server host WORD<0-255> used-by {cli|eapol|endpoint-tracking|snmp|web} secure-log-level command.
Variable | Value |
<critical | debug | error | info | warning> |
Specifies the RADIUS secure server log severity level. The default is error. |
used-by {cli|eapol|endpoint-tracking|snmp|web} |
Configures how the server functions:
WORD<0-113> |
Configures a host server. WORD<0-113> specifies the IPv4 address, IPv6 address, or fully qualified domain name (FQDN). If you use an FQDN, you must also configure the switch to use DNS. |
