operator
      Configures a unique name of the administrator or operator
         responsible for the configuration and management or the hotspot. The name can be configured
         in English or in any language other than English. When the name is specified in English,
         the system allows an ASCII input. If using a language other than English, first specify the
         ISO-639 language code, and then specify the name as an hexadecimal code.
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
         operator name [<OPERATOR-NAME>|iso-lang <ISO-639-LANG-CODE> <OPERATOR-NAME>]
      Parameters
                     | name <OPERATOR-NAME> | Configures the operator‘s name in English
                           <OPERATOR-NAME> – Specify the operator name in
                              ASCII format. The name cannot exceed 252 characters. |
                        <OPERATOR-NAME> | Configures the operator‘s name in any language
                        other than English
                           iso-lang <ISO-639-LANG-CODE> – Specify the three-character
                              ISO-14962-1997 encoded string defining the language used in the Code
                              field. For example, chi or spa.
                                 <OPERATOR-NAME> – Specify the operator name in Hexadecimal
         nx9500-6C8809(config-passpoint-policy-test)#operator name exampleoperator
         nx9500-6C8809(config-passpoint-policy-test)#show context
passpoint-policy test
 access-network-type chargeable-public
 connection-capability ip-protocol 2 port 10 closed
 nai-realm example
  eap-method 1 ttls auth-param vendor hex 00001E
  eap-method 2 rsa-public-key auth-param credential cert
 net-auth-type accept-terms url www.test.com
 3gpp mcc 505 mnc 14
      Related Commands
                     | no | Removes the operator's name configured for this
                           passpoint policy |
