Adds an osu (online sign up) SSID (WLAN)/OSU provider and enters its configuration mode
Passpoint certificates are governed by the Hotspot 2.0 OSU Certificate Policy Specification. An OSU server certificate should be obtained from any of the CAs authorized by the Wi-Fi Alliance.
Once an OSU provider is selected, the client connects to the OSU WLAN (Open or OSEN). It then triggers an HTTPS connection to the OSU server, which was received with the OSU providers list. The client validates the server certificate to ensure it's a trusted OSU server. The client is then prompted to complete an online registration through their browser. When the client has a valid credential for the hotspot 2.0 WLAN, it disassociates from the OSU WLAN and connects to the hotspot 2.0 WLAN using standard ANQP mechanisms.
osu [provider <PASSPOINT-OSU-PROVIDER>|ssid <SSID>]
| osu | Use this command to configure an OSU SSID/OSU provider. |
| provider <PASSPOINT-OSU-PROVIDER> | Creates an OSU provider for this passpoint and enters
| ssid <SSID> | Configures an OSU WLAN‘s SSID. This is the open
                authentication SSID that a user can use to obtain credentials for the passpoint
                SSID.
nx9500-6C8809(config-passpoint-policy-test)#osu provider test nx9500-6C8809(config-passpoint-policy-test-osu-provider-test)#? Passpoint OSU Provider Mode commands: description Configure the English description of the online signup provider icon Add an icon for the online signup provider method Specify the online signup method supported by provider nai Configure the NAI for the online signup provider name Configure the english name of the online signup provider no Negate a command or set its defaults server-url Configure the signup url for the online signup provider clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-passpoint-policy-test-osu-provider-test)#
| Command | Description |
| description (osu-config-mode) | Configures the OSU provider‘s description |
| icon (osu-config-mode) | Adds the OSU provider‘s icon |
| method (osu-config-mode) | Configures the open sign up methods available on this OSU provider |
| nai (osu-config-mode) | Configures the OSU provider‘s NAI |
| name (osu-config-mode) | Configures the OSU provider‘s name |
| server-url (osu-config-mode) | Configures the OSU provider server‘s URL |
| no (osu-config-mode) | Removes the settings configured for this OSU provider |
| no | Removes the OSU WLAN/provider configured with this passpoint policy |
