assoc-response
Configures the deny-threshold and
rssi-threshold values. These threshold values are considered when responding to a client‘s
association/authentication request.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
assoc-response [deny-threshold <1-12>|rssi-threshold <-100--40>]
Parameters
| assoc-response |
Configures the association response thresholds |
| deny-threshold <1-12> |
Configures the number of times association/authentication request, from a
client, is ignored if the RSSI is less than the configured RSSI threshold. This
option is disabled by default.
- <1-12> – Specify the
deny-threshold from 1 - 12.
| rssi-threshold <-100--40> |
Configures an association response RSSI threshold value. If the RSSI is below
the configured threshold value, the client‘s association/authentication request is
ignored. This option is disabled by default. rssi-threshold
- <-100--40> – Specify a
value from -100 - -40 dBm.
nx9500-6C8809(config-wlan-test)#assoc-response rssi-threshold -60
nx9500-6C8809(config-wlan-test)#assoc-response deny-threshold 4
nx9500-6C8809(config-wlan-test)#show context
wlan test
ssid test
bridging-mode local
encryption-type none
authentication-type none
registration user group-name guest expiry-time 2000 agreement-refresh 14400
