Configures the OSU SSID/provider‘s description. This value is returned in the ANQP OSU providers list.
description [<DESCRIPTION>|iso-lang <ISO-LANG-CODE> <DESCRIPTION>]
| <DESCRIPTION> | Configures the OSU provider‘s description in English. It
                should not exceed 253 characters in length.
 Note: If configuring description in any language other than English, use the
                  'iso-lang' option to provide the language code.
| iso-lang <ISO-LANG-CODE> <DESCRIPTION> | Identifies the language by its ISO 639 language code
                (for example, ‘chi-chinese‘ or ‘spa-spanish‘). By default the language is set to
                English. If specifying the description in any language other than English, specify
                the ISO language code.
nx9500-6C8809(config-passpoint-policy-test-osu-provider-test)#description "OSU created for testing purposes."
      nx9500-6C8809(config-passpoint-policy-test-osu-provider-test)#show context osu provider test description "OSU created for testing purposes." nx9500-6C8809(config-passpoint-policy-test-osu-provider-test)#
| no (osu-config-mode) | Removes this OSU provider‘s description |
