Configures the authentication-type filter for this user-defined role
authentication-type [any|eq|neq]
authentication-type any
authentication-type [eq|neq] [eap|kerberos|mac-auth|none]
{(eap|kerberos|mac-auth|none)}
                         any  |
                     The authentication type is any (eq or neq). This is the default setting. |
                         eq [eap|kerberos| mac-auth|none]  |
                     The role is applied only when the authentication
                        type matches (equals) one or more than one of the following types:
 Note: These parameters are recursive, and you can configure more than
                           one unique authentication type for this user-defined role.
                         neq [eap|kerberos| mac-auth|none]  |
                         The role is applied only when the authentication type does not match (not equals) any of the following types:
 Note: These parameters are recursive, and you can configure more than one
                           unique ‘not equal to‘ authentication type for this user-defined
                           role.
nx9500-6C8809(config-role-policy-test-user-role-testing)#authentication-type eq kerberos
         nx9500-6C8809(config-role-policy-test-user-role-testing)#show context user-role testing precedence 10 authentication-type eq kerberos ap-location contains office nx9500-6C8809(config-role-policy-test-user-role-testing)#
| no |
                         Removes the authentication type filter configured for this user-defined role  |
