Configures upstream/downstream rate limits and VLAN ID. Clients matching this user-defined role filters are associated with the specified VLAN, and assigned the specified data rates.
assign [rate-limit|VLAN]
assign rate-limit [from-client|to-client] <1-65536>
assign vlan <1-4094>
                         assign rate-limit [from-client|to-client] <1-65536>  |
                         Assigns an upstream and downstream traffic rate limit
 Note: Wireless clients matching this user-defined role are assigned the
                           configured rate limits.
                         assign vlan <1-4094>  |
                         Assigns a VLAN (identified by VLAN‘s ID). Clients matching this user-defined role are associated with the specified VLAN. The VLAN ID represents the shared SSID each user employs to interoperate within the network (once authenticated by the local RADIUS server). This feature is disabled by default.
 Note: A wireless client that fails to match any user-defined role is
                           assigned to the default role (configured as a role policy setting) and is
                           mapped to the default VLAN under the WLAN.
ACLs can only be used with tunnel or isolated-tunnel modes. They do not work with the local and automatic modes.
In case of bridge VLAN, the default bridging mode is ‘auto‘. Change the bridging mode to ‘tunnel‘. This extends the controller‘s existing VLAN onto the AP and ensures that wireless clients are served IP addresses.
The VLAN configured under the user-defined role need not exist under the WLAN. But, when using tunneled VLAN bridges, configure an additional bridge VLAN. If the VLAN bridging mode is ‘local‘, no additional VLAN configuration is required.
nx9500-6C8809(config-role-policy-test-user-role-test)#assign rate-limit to-client 200
nx9500-6C8809(config-role-policy-test-user-role-test)#commit
nx9500-6C8809(config-role-policy-test-user-role-test)#show context user-role test precedence 1 assign vlan 1 assign rate-limit to-client 200 nx9500-6C8809(config-role-policy-test-user-role-test)#The following examples define a role used to forward the IP traffic from all engineers in Test_Company, Santa Clara, USA onto VLAN 2.
<DEVICE>(config)#role-policy test-policy
<DEVICE>(config-role-policy-test-policy)#ldap-query self
<DEVICE>(config-role-policy-test-policy)#ldap-server 1 host 192.160.1.1 bind-dn CN=Administrator,CN=Users,DC=testtest,DC=com base-dn CN=Administrator,CN=Users, DC=com bind-password 0 test port 389
<DEVICE>(config-role-policy-test-policy)#ldap-timeout 2
<DEVICE>(config-role-policy-test-policy)#user-role SCEngineer precedence 100
<DEVICE>(config-role-policy-test-policy-user-role-SCEngineer)#city exact santa-clara
<DEVICE>(config-role-policy-test-policy-user-role-SCEngineer)#company exact ExampleCompany
<DEVICE>(config-role-policy-test-policy-user-role-SCEngineer)#country exact usa
<DEVICE>(config-role-policy-test-policy-user-role-SCEngineer)#title contains engineer
<DEVICE>(config-role-policy-test-policy-user-role-SCEngineer)#assign vlan-id 2
ap8432-5C63F0(config-device-74-67-F7-5C-63-F0)# use role-policy test-policy
                         Removes the upstream and/or downstream rate limits applied to this user-defined role. Also removes the VLAN ID.  |
