wing-extensions [ap-attributes-information {include-hostname}|
coverage-hole-detection {11k-clients|offset <5-20>|threshold <-80--60}|
ft-over-ds-aggregate|move-command|scan-assist {channel-info-interval <6-9>}|
smart-scan|wing-load-information|wmm-load-information]
         | wing-extensions | Enables support for inclusion of WiNG-specific client extensions in radio transmissions |
| ap-attributes-information {include-hostname} | Enables support for AP attributes IE (information element)
 AP attributes IE is not added to beacons and probe responses by default.  |
| overage-hole-detection {11k-clients| offset <5-20>| threshold <-80--60>} | Enables coverage hole detection (CHD) and configures CHD
                        parameters. When enabled, allows clients (MUs) to inform an access point
                        when it experiences a coverage hole. A coverage hole is an area of poor
                        wireless coverage not supported by a WiNG managed access point radio. Enable radio resource measurement
                        prior to enabling CHD. For enabling radio resource measurement, see radio-resource-measurement. CHD is disabled by default.  After enabling CHD,
                           optionally configure the following parameters:
| ft-over-ds-aggregate | Enables fast-transition (FT) aggregation of action frames. When
                        enabled, increases roaming speed by eliminating separate key exchange
                        handshake frames with potential roam candidates. Enable fast transition to
                        complete an initial FT over distribution system (DS) handshake with
                        multiple roam candidates (up to 6) at once, eliminating the need to send
                        separate FT over DS handshakes to each roam candidate. This option is disabled by default.  |
| move-command | Enables use of Hyper Fast Secure Roaming (HFSR) for clients on this WLAN. This feature applies only to certain client devices. This option is disabled by default. |
| scan-assist {channel-info-interval <6-9>} | Enables support for scanning assist. When enabled, allows faster roams
                        on Dynamic Frequency Selection (DFS) channels by eliminating passive
                        scans. Clients get channel information directly from possible roam
                        candidates. This option is disabled by default.
| smart-scan | Enables a smart scan to refine a clients channel scans to just a few channels as opposed to all available channels. This option is disabled by default. |
| wing-load-information | Enables support for the WiNG load information element (Element ID 173) with legacy Symbol Technology clients, thus making them optimally interoperable with the latest Extreme Networks access points. This option is enabled by default. |
| wmm-load-information | Enables support for WiNG Wi-Fi MultiMedia (WMM) Load Information Element in radio transmissions with legacy clients. This option is disabled by default. |
nx9500-6C8809(config-wlan-test)#wing-extensions wmm-load-information
         nx9500-6C8809(config-wlan-test)#show context wlan test description TestWLAN ssid test bridging-mode local encryption-type tkip-ccmp authentication-type eap kerberos server timeout 12 kerberos server primary host 172.16.10.2 accounting syslog host 172.16.10.4 port 2 data-rates 2.4GHz gn wing-extensions wmm-load-information client-load-balancing probe-req-intvl 5ghz 5 --More-- nx9500-6C8809(config-wlan-test)#
| no (wlan-config-mode) | Disables support for WiNG-specific client extensions to the IEEE 802.11x WLAN standards. Use the keywords provided to disable a specific wing-extension. |
