vlan [<1-4094>|<VLAN-ALIAS-NAME>]
| <1-4094> | Sets a WLAN‘s VLAN ID. This command starts a new
                        VLAN assignment for a WLAN index. All prior VLAN
                        settings are erased. Use this command to assign just one VLAN to the WLAN. Utilizing a single VLAN per WLAN is a more typical deployment scenario than using a VLAN pool.  |
| <VLAN-ALIAS-NAME> | Assigns a VLAN alias to the WLAN. The VLAN alias
                        should be pre-existing and configured. A VLAN alias maps a name to a VLAN ID. When applied to ports (for example GE ports) using the trunk mode, a VLAN alias denies or permits traffic, on the port, to and from the VLANs specified in the alias. For more information on aliases, see alias.  |
nx9500-6C8809(config-wlan-test)#vlan 4
         nx9500-6C8809(config-wlan-test)#show context wlan test ssid testWLAN1 vlan 4 bridging-mode local encryption-type none authentication-type none protected-mgmt-frames mandatory radius vlan-assignment time-based-access days weekdays start 10:00 end 16:30 wing-extensions wmm-load-information client-load-balancing probe-req-intvl 5ghz 5 client-load-balancing band-discovery-intvl 2 use aaa-policy test use association-acl-policy test acl exceed-rate wireless-client-denied-traffic 20 disassociate proxy-arp-mode strict broadcast-dhcp validate-offer shutdown on-unadoption http-analyze controller nx9500-6C8809(config-wlan-test)#
| no (wlan-config-mode) | Removes a WLAN‘s default VLAN mapping |
