Caution
There are no user-serviceable components inside the NX-7500 series integrated services platform. Opening the chassis will void the warranty.Caution
BIOS settings on the NX-7500 series integrated services platform should not be changed. Changing any settings in the BIOS will void the warranty on the integrated services platform.Caution
To prevent the integrated services platformfrom overheating, never install in an enclosed area not properly ventilated or cooled. For proper airflow, keep the front and back sides of the integrated services platform clear of obstructions and away from the exhaust of other equipment.Caution
The recommended operating temperature is 32ºF to 104ºF/0ºC to 40ºC. Installation in a closed or multi-rack assembly may raise the immediate ambient temperature above the average room temperature. Exercise due caution.Caution
Ensure the electrical circuit through which the integrated services platform is powered can safely accommodate a 300 Watt power supply.Caution
It is recommended you connect the NX-7500 series integrated services platform to an Uninterruptible Power Supply (UPS). There are instances in which the system software could become corrupt and un-recoverable in the event of power loss, for example, during a system upgrade, database backup or database restore operation.
