Accessories
The following accessories are available for NX-7500 series Integrated
Services Platform:
- 2 port 10Gb Network Mezzanine Card (NMC) module for use with 10Gb SFP+ transceivers
- 10GbPS short range 850nm multi-mode SFP+ transceiver for use with 10Gb NMC
- 10GbPS long range 10km single-mode SFP+ transceiver for use with 10Gb NMC
- 4 port 10Gb NMC Module for use with 1Gb SFP transceivers
- 1GbPS short range SFP transceiver for use with 1Gb NMC
- 1GbPS long range SFP transceiver for use with 1Gb NMC
- Spare AC power supply for NX-7510 or NX-7530
- Spare DC power supply for NX-7510 or NX-7530
- Mounting kit with sliding rails
- Spare 500GB hard drive for NX-7530
Additional Recommended Equipment:
- Standard, grounded 100-240 VAC 50/60 Hz connection
- Standard 19-inch 1U height equipment rack
- Depending on the power supply, an AC or DC Uninterruptible Power Supply (UPS) is
recommended
