Basic Configuration Using the Management Interface
    Once the NX 9600 series controller hardware is installed and powered on,
      complete the following to access the Management Interface functions:
      - Connect one end of an Ethernet cable to one of the ports on the back of the NX-9600 series
        controller, and connect the other end to a computer with a working Web browser.
- Set the computer to use an IP address between 192.168.0.10 and 192.168.0.254
        on the connected port. Set a subnet /network mask of 255.255.255.0.
- Once the computer has an IP address, point the Web browser to: https://192.168.0.1. The
        following login screen displays:Management Interface Login Screen
- Enter the default username admin in the Username field.
- 5. Enter the default password admin123 in the Password
        field.
- Click Login. You are prompted to change your password.
- Enter a new password, then enter it again to confirm it.
- Click Apply. The password change is confirmed.Password Change Confirmation
- Click OK. The NX-9600 Dashboard displays.
You have now established a connection to the NX-9600 Management Interface.
