Using the NX-9600 Series Command Line Interface
    Once the NX-9600 series hardware is installed, complete the following to
      access the Command Line Interface (CLI) on the controller:
      - On the configuration computer, configure a terminal emulation application as
          follows:
            | Terminal Type | VT 100 |
            | Port | COM port |
            | Terminal Settings |
                19200bps transfer rate8 data bitsno parity1 stop bitno flow controlno hardware compression |
- Apply power to the device.
- When the prompt is displayed in the terminal window, login using the username
          admin and password admin123.
- For increased security, you are prompted to enter a new password. Enter the new password
        then enter it again to confirm it.
