Use this procedure to change the default gateway of a TPVM. This procedure has no impact on the functioning of EFA high-availability mode.
Ensure that the gateway IP address is in the same subnet as one of the subinterfaces that are created in EFA.
efa mgmt subinterface staticip --name <sub-int-name> --ip1 <ip-addr> --ip2 <ip-addr>
efa inventory device execute-cli --ip <standby-slx-ipaddr> --command="tpvm stop"
efa inventory device execute-cli --ip <standby-slx-ipaddr> --command "tpvm TPVM,interface management ip <standby-tpvm-ipaddr> gw <new-gateway-ipaddr>" --config
efa inventory device execute-cli --ip <standby-slx-ipaddr> --command="tpvm start"
efa inventory device execute-cli --ip <active-slx-ipaddr> --command="tpvm stop"
efa status
efa inventory device execute-cli --ip <active-slx-ipaddr> --command "tpvm TPVM,interface management ip <active-tpvm-ipaddr> gw <new-gateway-ipaddr>" --config
efa inventory device execute-cli --ip <active-slx-ipaddr> --command="tpvm start"
