| EAPS Advanced Edge (multiple physical
rings) |
All platforms. |
| ERPS-more domains (allows 32 rings with
matching ring ports) and multi-ring support |
All platforms. |
| ESRP-Full |
All platforms. |
| ESRP-Virtual MAC |
All platforms. |
| OSPFv2-Edge (limited to max of 4 active
interfaces) |
All platforms that support the Advanced Edge
or Core licenses.1 |
| OSPFv3-Edge (limited to max of 4 active
interfaces) |
| PIM-SM-Edge (limited to max of 4 active
interfaces) |
| VRRP |
| VXLAN |
Summit X770 and X670-G2. |
| OVSDB |
| PSTag |
All platforms. |
