Advanced Edge License Features
The Advanced Edge License includes all Edge License features and the features in the following table.
ExtremeXOS Advanced Edge License Features
ExtremeXOS Software Feature Supported Platforms
EAPS Advanced Edge—multiple physical rings, and "common links", also known as "shared port". All platforms.
ERPS-more domains (allows 32 rings with matching ring ports) and multi-ring support All platforms.
ESRP-Full All platforms.
ESRP-Virtual MAC All platforms.
OSPFv2-Edge (limited to max of 4 active interfaces) All platforms that support the Advanced Edge or Core licenses (see Standard and Upgrade Licenses for ExtremeXOS Switches).
OSPFv3-Edge (limited to max of 4 active interfaces) All platforms that support the Advanced Edge or Core licenses (see Standard and Upgrade Licenses for ExtremeXOS Switches).
PIM-SM-Edge (limited to max of 4 active interfaces) All platforms that support the Advanced Edge or Core licenses (see Standard and Upgrade Licenses for ExtremeXOS Switches).
VRRP All platforms that support the Advanced Edge or Core licenses (see Standard and Upgrade Licenses for ExtremeXOS Switches).
VXLAN Summit X770, X670-G2, and ExtremeSwitching X870, X690.
OVSDB Summit X770, X670-G2, and ExtremeSwitching X870, X690.
PSTag Summit X460-G2, X670-G2, X770, and ExtremeSwitching X870, X690 series switches.
