Checks the operability of the MPLS LDP-signaled label switched path (LSP) connections.
The following example displays the output of the command with LDP IP address 130.130.130.1/32.
device# ping mpls ldp 130.130.130.1 Send 5 84-byte MPLS Echo Requests for LDP FEC 130.130.130.1/32, timeout 5000 msec Type Control-c to abort !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max=0/1/2 ms. device# ping mpls ldp 130.130.130.1/32 Send 5 84-byte MPLS Echo Requests for LDP FEC 130.130.130.1/32, timeout 5000 msec Type Control-c to abort !!!!! Success rate is 100 percent (5/5), round-trip min/avg/max=0/0/1 ms.
The following example is the corresponding output of the show mpls ldp tunnel command.
device# show mpls ldp tunnel
Total number of LDP Tunnels:2
Oper Tunnel Outbound
To State Intf Intf
130.130.130.1/32 UP tnl1 Eth 1/5
120.120.120.1/32 UP tnl0 Eth 1/5
