BFD for Static RoutesNEW!
A static route is associated with a
static BFD when the next-hop for the static route matches the neighbor address of the static
BFD neighbor and BFD monitoring is enabled for the static route.
To use BFD for static routes, configure static routes (IPv4 or IPv6) and the corresponding
static BFD separately. When static BFD is configured, the static route manager checks
the routing table (RIBMGR) for a route to the BFD neighbor.
- If a route exists and the
next-hop is directly connected, a single-hop session is created.
- If the next-hop is not directly
connected, a multi-hop BFD session is created.
When the BFD session is up, a corresponding static route is added to RIBMGR. When the BFD
session that monitors the static route goes down because the BFD neighbor is not
reachable, static routes are removed from RIBMGR. These removed routes are replaced in
RIBMGR when the BFD neighbor is reachable.
Single-hop BFD sessions use timeout values that are configured on the outgoing interface from
which the BFD neighbor is reachable. Timeout values for multi-hop BFD sessions are
specified with the static BFD neighbor. Multiple static routes with the same BFD
neighbor use the same BFD session and timeout values.
Considerations for BFD for static routes
- When you configure a static BFD for a
neighbor and the neighbor is reachable, a request is made to BFD to establish a
BFD session.
- A single-hop BFD static route session uses the timer values that are configured
for the outgoing interface to the directly connected neighbors. A multi-hop BFD
static route session uses the timer values that are configured in the CLI. If
these timer values conflict with the timer values set for BGP, for the same
next-hop, then BFD uses the smaller value to meet the more stringent
requirement.
- After a reboot of the device,
global config-replay happens
before interface config-replay. In such a situation, static BFD
sessions can be created before static routes are added to RIBMGR. Therefore, for
SLX-OS, BFD sessions are created only when the next-hop is reachable.
- If you remove the static BFD session, BFD
takes down the corresponding session without removing static routes from routing
table. Ongoing traffic is not interrupted.
- If a BFD session goes down because the BFD neighbor is not reachable, the
associated static routes are removed from RIBMGR. Traffic is interrupted on
these static routes.
- If the maximum number of BFD sessions is
reached, a BFD session may not come up. In such a situation, a BFD session is
not created for the related static route and the route is not removed from
RIBMGR.
BFD for IPv6 static routes
If the BFD neighbor is link-local, the source IPv6 address must also be link-local.
If an IPv6 BFD session is running for a link-local BFD neighbor, the
interface-type and interface-name
parameters (for the ipv6 route static bfd command) are mandatory
because the link-local address can be the same on multiple interfaces.
Supported Platforms
BFD for static routes is supported on SLX 9150 and SLX 9250.
