Extreme SLX-OS QoS and Traffic Management Configuration Guide, 20.2.1
About This Document
> What's New in this Document
Published June 2020
Preface
Getting Help
Providing Feedback
About This Document
Supported Hardware
Traffic Policing
Traffic Policing Overview
Policy Maps
Traffic Policing Behaviors
Class Maps
Two-rate, three-color marker
Control Plane Policing
CoPP Rate Limiting
CoPP-related Commands
VLAN-based rate limiting
Receive ACL Rate Limiting
Egress ACL Rate Limiting
TTL 0/1 Rate Limiting
Subnet Trap Rate Limiting
Rate Limiting Scalability
Configuring traffic policing
Configuring a policy map
QoS overview
QoS on the SLX 9150 and SLX 9250 Devices
Congestion control
How WRED works
Applying WRED
Link Level Flow Control
Scheduling
Scheduling types
Multicast queue scheduling
Ingress QoS mutation
Egress QoS Mutation
QoS Mutation Maps
Configuring DSCP mappings
Configuring DSCP-to-CoS mappings
Configure a DSCP-to-CoS Mutation Map
Applying a DSCP-to-CoS mutation map to an interface
DSCP-to-Traffic Class Mappings
Configuring WRED
Enable Priority Flow Control
Configuring scheduling
Flow-based QoS
Traffic Management Counters and Statistics
The following table describes information added to this guide for the SLX-OS 20.2.1 software release.
Table 1.
Summary of changes
Feature
Description
Described in
Control Plan Policing
New feature for this release.
For complete information on this SLX-OS software release, refer to the
SLX-OS Release Notes
