Extreme SLX-OS QoS and Traffic Management Configuration Guide, 20.3.3
> About This Document
Published October 2021
Preface
About This Document
What's New in this Document
Supported Hardware
Traffic Policing
Traffic Policing Overview
Policy Maps
Traffic Policing Behaviors
Class Maps
Two-rate, three-color marker
Control Plane Policing
CoPP Rate Limiting
CoPP-related Commands
VLAN-based rate limiting
Receive ACL Rate Limiting
Egress ACL Rate Limiting
TTL 0/1 Rate Limiting
Subnet Trap Rate Limiting
Rate Limiting Scalability
Configuring traffic policing
Configuring a policy map
QoS overview
QoS on the SLX 9150 and SLX 9250 Devices
Congestion control
How WRED works
Applying WRED
Link Level Flow Control
Explicit Congestion Notification
Hardware Buffer Configuration for Lossless Traffic
Scheduling
Scheduling types
Multicast queue scheduling
Ingress QoS mutation
Egress QoS Mutation
QoS Mutation Maps
Configuring DSCP mappings
Configuring DSCP-to-CoS mappings
Configure a DSCP-to-CoS Mutation Map
Applying a DSCP-to-CoS mutation map to an interface
DSCP-to-Traffic Class Mappings
Configuring WRED
Enable Priority Flow Control
Configuring Hardware Buffer for Lossless Traffic
Displaying the RED Profile and dropped packets information for an interface
Configuring Explicit Congestion Notification
Configuring Enhanced Transmission Selection
LLDP TLVs for Enhanced Transmission Selection
Priority Flow Control Configuration TLV
Enhanced Transmission Selection (ETS) Recommendation TLV
Link Aggregation TLV
Configuring scheduling
Flow-based QoS
Traffic Management Counters and Statistics
About This Document
