Considerations for SLX 9540 and SLX 9640
devices
Keep the following things in mind when configuring SPAN/RSPAN/ERSPAN on SLX 9540,
SLX 9640, and SLX 9740 devices.
- SLX 9540 and SLX 9640 do not support RSPAN/ERSPAN. They also do not support the new CLI
for configuring flow-based SPAN.
- The devices support fifteen (15) hardware SPAN sessions.
- One unique SPAN destination in the monitor session configuration consumes one hardware
SPAN session.
- Twelve sessions are reserved for VxLAN visibility features, snooping applications, and
flow-based SPAN sessions.
- Therefore, you can configure
three different destinations for port mirroring. If you try to configure mirror
sessions with more than three different destination ports, the configuration
fails and generates a RASLog message. You have to manually remove the failed
configuration.
- The application telemetry feature
consumes one hardware SPAN session. If you configure application telemetry, you
can configure only two monitor sessions, each with a unique destination, or
multiple monitor sessions that share one of the SPAN destination.
