When a receiving device is congested, it communicates with the transmitting device by sending a PAUSE frame that instructs the device to stop data transmission for a specific time. This feature is available for each port in all front ports and applies to all traffic on the link. Extreme supports the generation (Tx) and reception (Rx) of PAUSE frames for each physical interface or port channel.
By default, LLFC reception is enabled.
Refer to Configuring link level flow control for the steps to configure LLFC.
Pause and PFC LLFC are supported only on the following devices, Extreme 8720, Extreme 8520, SLX 9740, SLX 9640, SLX 9540, SLX 9250, and SLX 9150.
