Maintenance Association Identifier (MAID) is a 48 byte field included in the Continuity Check Message (CCM) frame to identify the Maintenance Domain (MD) and Maintenance Association (MA) to which this CCM belongs to. This helps in detecting cross connection errors in the service.
By default, short MAID format is configured when a MA is configured. You can set the MAID format for a particular maintenance association to long, using the maid-format command.
device(config)# protocol cfm device(config-cfm)# domain name md1 level 4 device(config-cfm-md-md1)# ma-name ma1 id 30 vlan-id 30 priority 7 device(config-cfm-md-md1)# maid-format long
The no form of the command sets the maid format back to short. For more information on commands, please refer the SLX-OS Command Reference guide.
The maid format cannot be changed after a MEP is configured under that MA. You must delete the MEP and then change the MAID format.
