gRPC-server streaming
In this telemetry implementation, your monitored device functions as a Google remote procedure call (gRPC) server, streaming data in response to calls from gRPC clients.
The telemetry profiles currently configured with interfaces determine the monitored attributes and the streaming intervals. For details, refer to Telemetry profiles. Client RPCs must be crafted to request streaming per telemetry profile.
The telemetry server command offers an option to specify a VRF other than the default mgmt-vrf.
From telemetry-server configuration mode, you can modify the following default settings:
From telemetry-server configuration mode, you also activate and deactivate the gRPC server.
The following diagram illustrates the gRPC-server telemetry implementation:
