Front and Back Panel Information
Use the information in the following sections to identify the hardware features located on the front and rear panel.
The 3160C has the following hardware features located on the front panel.
The 3160C Front Panel
The 3160C front panel
Table 1. 3160C Front Panel
CalloutDescription
1.Information LED, ICC2 LED, ICC1 LED, HDD LED, and Power LED
2.UID
3.Power On
4.DB9 Console port
5.USB 2.0 ports
6. USB 3.2 ports
7.Inter-Cluster-Connect port 1
8.Inter-Cluster-Connect port 2
9.VGA port (do not use)
10.Data port 1 and 2, 1/10/25 GbE SFP28
11.Data port 3 and 4, 10/25/50/100 GbE QSFP28
The 3160C has the following hardware features located on the back panel.
The 3160C Back Panel
The 3160C back panel
Table 2. The 3160C Back Panel
CalloutDescription
1Cooling fans
2Back-up power supply units
