Mount the Appliance
You can mount the appliance in a 19-inch rack using the rail mount kit included with the 3160C.
Wear an anti-static wrist strap when you handle the appliance to avoid damaging the device or the components.
You can also mount the appliance on a tabletop or shelf. Ensure at least 2.5 in. (6 cm) of clearance on all sides of the unit for proper ventilation.
