Install Your Switch
Before you attempt to install or remove an Extreme Networks switch, read the precautions in Safety Considerations for Installation.
If you are installing switches for use in a stacking configuration, read Build Stacks before you install the switches.
Extreme Networks switches fit into standard 19-inch equipment racks.
The installation process includes the following tasks:
Table 1. Switch Installation Tasks
StepProcedureDescription
1What You Will Need for the Installation Prepare to install the switch
2Attach the Switch to a Rack or Cabinet Mount the switch, or install the switch in the rack.
3Install Expansion Modules Install expansion modules, if the switch supports expansion modules.
4Install Optional Components Install optional components: optical transceivers and cables.
5Install an Optional Modular Internal AC Power Supply Install an optional modular AC power supply.
6Connect the Switches to Form the Stack Ring Connect stacking cables for a stacked configuration.
7Connect Network Interface Cables Connect network interface cables.
8Turn on the Switch Power up the switch.
9Activate and Verify the Switch Perform initial network connection and configuration.
