Power Specifications
Power Supply Specifications
Switch ModelInternal Fixed PSU - Max PowerSecondary PSU
4120-24MW-4Y860W ACPSUXN-ACPWR-920W-FB-U
XN-ACPWR-1200W-FB-U
4120-48MW-4Y1200W ACPSUXN-ACPWR-1200W-FB-U
XN-ACPWR-2000W-FB-U
Max PoE Power Budget
Switch ModelWith Internal Fixed PSU With Internal Fixed PSU + 920W PSUWith Internal Fixed PSU + 1200W PSU With Internal Fixed PSU + 2000W PSU
4120-24MW-4Y (100-120VAC)680W1440W1380WNot Supported
4120-48MW-4Y (100-120VAC)640WNot Supported1340W1230W
4120-24MW-4Y (200-240VAC)680W1440W1540WNot Supported
4120-48MW-4Y (200-240VAC)980WNot Supported1780W2180W
Minimum/Maximum Power Consumption and Heat Dissipation
Switch Model Minimum Power Consumption (W) Minimum Heat Dissipation (BTU/hr) Maximum Power Consumption (W)*Maximum Heat Dissipation (BTU/hr)**
4120-24MW-4Y481641830990
4120-48MW-4Y5619125351211
