On some Extreme Networks switch models, you can configure QSFP28, QSFP56-DD, SFP56-DD, or SFP28 ports either as single ports or as multiple, channelized ports. In a channeled port, with appropriate cabling, the original physical port can accommodate multiple data lanes at lower bandwidths. Ports are not channelized by default.
Only odd numbered ports can be channelized. When an odd numbered port is channelized the next even numbered port is not available for data traffic. For example, if port 1 is channelized port 2 is not available.The following options are available:
| Device | Port Bandwidth | Port Channels |
| (all models) QSFP28 (ports 1 - 32) | 100 Gb | One of the following:
| (all models) QSFP56-DD (ports 1 - 8) | 400 Gb | One of the following:
| 7830-VIM-8DE QSFP56-DD (ports 1 - 8) | 400 Gb | One of the following:
| 7830-VIM-16CE QSFP28 (ports 1 - 16) | 100 Gb | One of the following:
| 7830-VIM-24CE SFP56-DD (ports 1 - 24) | 100 Gb | One of the following:
| 7830-VIM-24YE SFP28 (ports 1 - 24) | 25 Gb | One of the following:
For information about configuring channelized ports, see the Fabric Engine Command References for your version of the Fabric Engine operating system.
