aaa/authentication/login/third
Configures the tertiary source of authentication.
Usage
<aaa-config xmlns="urn:brocade.com:mgmt:brocade-aaa">
	<aaa>
		<authentication>
			<login>
				<third>
					{local-auth-fallback}
				</third>
			</login>
		</authentication>
	</aaa>
</aaa-config>
Parameters
authentication
Specifies authentication.
login
Specifies login.
third
Specifies tertiary source. The only available option is local-auth-fallback. This setting has no effect if the secondary fallback authentication is configured to local-auth-fallback.
