Extreme Networks, Inc. July 15, 2025
Search this document Print this page Email this page View PDF Previous Next
NETCONF Statements
Section contents:
aaa Configures AAA authentication, accounting, and administration. aaa/accounting Configures login or command accounting; either commands or login information are forwarded to accounting servers. aaa/authentication Configures the AAA login sequence. aaa/authentication/login Configures the AAA login sequence. aaa/authentication/login/first Configures the primary source of authentication. aaa/authentication/login/second Configures the secondary fallback source of authentication. aaa/authentication/login/third Configures the tertiary source of authentication. aaa/username Configures a username and password for AAA login. aaa/username/desc Adds describes for the username. aaa/username/encryption-level Configures the encryption level for a username. aaa/username/role Configures the role of the user. acl-policy Configures, modifies, or retrieves the ACL configuration. acl-policy/allow-conflicting-rules Allows conflicting rules in an ACL table. acl-policy/allow-duplicate-rules Allows duplicate rules in an ACL table.. arp Configures, modifies, or retrieves Address Resolution Protocol (ARP). bridge-domain Configures a bridge domain. bridge-domain/(bridge-domain-id)/(bridge-domain-type)/bpdu-drop-enable Enables the Bridge Protocol Data Units (BPDU)-drop feature. bridge-domain/(bridge-domain-id)/(bridge-domain-type)/logical-interface Configures the logical interface. bridge-domain/(bridge-domain-id)/(bridge-domain-type)/local-switching Configures local switching. bridge-domain/(bridge-domain-id)/(bridge-domain-type)/peer/(peer-ip)/cos Sets the cos value in the range 0 to 7. bridge-domain-id/(bridge-domain-type)/peer/(peer-ip)/load-balance Retrieves load-balancing details. bridge-domain/(bridge-domain-id)/(bridge-domain-type)/peer/(peer-ip)/lsp Configures label-switched paths (LSPs ). bridge-domain/(bridge-domain-id)/(bridge-domain-type)/pw-profile Sets the Pw-profile name. bridge-domain/(bridge-domain-id)/(bridge-domain-type)/statistics Configures statistics for a bridge domain? bridge-domain/(bridge-domain-id)/(bridge-domain-type)/vc-id Configures the VC ID for the bridge domain. chassis Configures, modifies, or retrieves the IP address of the virtual chassis. chassis/virtual-ip Configures the chassis the virtual IPv4 address. chassis/virtual-ipv6 Configures the chassis the virtual IPv4 address. clock Configures, modifies, or retrieves the system time zone. clock/time-zone Configures, modifies, or retrieves the system time zone. cluster/{cluster-name}/ Configures, retrieves, and modifies Multi-Chassis Trunking (MCT) cluster. config-drift-track/off Disables configuration drift tracking for the current session. config-drift-track/values Fetches the configuration drift values for current session. config-drift-track/status Displays Configuration Drift Tracking status for the current session.crypto-sa/crypto Configures the certificate expiry SNMP alarms. Four (4) severities of alarms can be configured with individual trigger duration. The four alarm severities are info , minor , major , and critical . The durations value can be configured between 1-90 days. dai Manages the IP access list. dai/arp/access-list Manages the IP access list. delay-link-event Manages the delay link event (DLE). dot1x Configures, retrieves, and modifies 802.1X authentication. dot1x/test Configures the 802.1X readiness test timeout. dot3ah Manages the Link OAM Protocol. event-handler Creates an event-handler profile. event-handler/{event-handler-name}/action Creates or accesses an event-handler profile, which can execute a Python script when a specified trigger occurs. get-tpvm-detail Displays the details for the TPVM instance.hardware Configures, modifies, or retrieves the hardware management configuration. interface/{interface-type}/{interface-name}/ethernet-segment/advertise Applies the AC-influenced-DF-election setting on the specified interface. interface/{interface-type}/{interface-name}/ip/access-group Applies rules specified in an access control list (ACL) to traffic entering or exiting an interface. interface/{interface-type}/{interface-name}/ip/arp-aging-timeout Configures how long an ARP entry stays in cache before the cache refreshes. interface/{interface-type}/{interface-name}/ip/dhcp/relay/gateway Configures the IP DHCP Relay on a Layer 3 gateway interface. interface/{interface-type}/{interface-name}/ip/igmp/immediate-leave Removes a group from the IGMP table immediately following receipt of a Leave Group request. interface/{interface-type}/{interface-name}/ip/igmp/last-member-query-count Sets the last-member query count. interface/{interface-type}/{interface-name}/ip/igmp/last-member-query-interval Configures last member query interval. interface/{interface-type}/{interface-name}/ip/igmp/query-interval Configures the query interval for a VLAN. The query interval is the amount of time between IGMP query messages sent by the switch. interface/{interface-type}/{interface-name}/ip/igmp/query-max-response-time Configures the maximum response time for IGMP queries interface/{interface-type}/{interface-name}/ip/igmp/robustness-variable Configures the robustness variable. interface/{interface-type}/{interface-name}/ip/igmp/startup-query-count Configures the start up query count. interface/{interface-type}/{interface-name}/ip/igmp/startup-query-interval Configures the start up query interval. interface/{interface-type}/{interface-name}/ip/pim/dr-priority Configures the designated router (DR) priority of a protocol Independent Multicast (PIM) enabled interface. interface/{interface-type}/{interface-name}/ip/pim/neighbor-filter By default, directly connected routers under protocol-independent multicast (PIM) form neighborship with one another. Using this command, you can block specified routers from neighborship. interface/{interface-type}/{interface-name}/ip/pim-sparse Enables Protocol Independent Multicast Sparse Mode. interface/{interface-type}/{interface-name}/ip/policy Enables policy-based routing (PBR) on any Layer 3 interface after ACLs and route map entries are configured. interface/{interface-type}/{interface-name}/ip/proxy-arp Enables proxy ARP on an interface. interface/{interface-type}/{interface-name}/ip/router/isis Configures the Intermediate System-to-Intermediate System (IS-IS) routing at the interface level. interface/{interface-type}/{interfacename}/ipv6/router/isis Configures the IS-IS routing protocol. interface/{interface-type}/{interface-name}/isis Configures the Intermediate System-to-Intermediate System (IS-IS) routing at the interface level. interface/{interface-type}/{interface-name}/link-error-disable Configures port link dampening (PLD). interface/{interface-type}/{interface-name}/link-fault-signaling Configures, retrieves, and modifies Link Fault Signaling (LFS). interface/{interface-type}/{interface-name}/ipv6/access-group Applies rules specified in an IPv6 access control list (ACL) to traffic entering or exiting an interface. interface/{interface-type}/{interface-name}/ipv6/dhcp/relay/address Configures the IPv6 DHCP Relay on a Layer 3 interface. interface/{interface-type}/{interface-name}/ipv6/nd/broadcast-mac-trap Enables the trap for all the IPv6 packets with broadcast mac. interface/{interface-type}/{interface-name}/ipv6/nd/cache Configures the time interval after which the IPv6 Neighbor Discovery cache is deleted or refreshed. interface/{interface-type}/{interface-name}/ipv6/nd/dad Configures the number of IPv6 Neighbor Discovery Neighbor Solicitation (NS) messages to be sent as part of duplicate address detection (DAD). interface/{interface-type}/{interface-name}/ipv6/nd/hoplimit Configures the number of hops to be advertised in IPv6 Neighbor Discovery Router Advertisement (RA) messages. interface/{interface-type}/{interface-name}/ipv6/nd/managed-config-flag In IPv6 Neighbor Discovery, indicates to hosts on a local link that they must use the stateful autoconfiguration feature to obtain IPv6 addresses for their interfaces. interface/{interface-type}/{interface-name}/ipv6/nd/mtu Sets the size of the maximum transmission unit (MTU) that is advertised in Neighhbor Discovery Router Advertisement (RA) messages. interface/{interface-type}/{interface-name}/ipv6/nd/ns-interval Configures the interval for address resolution between IPv6 Neighbor Discovery Neighbor Solicitation (NS) messages. interface/{interface-type}/{interface-name}/ipv6/nd/other-config-flag In IPv6 Neighbor Discovery, indicates to hosts on a local link that they can use the stateful autoconfiguration feature to obtain configuration settings other than IPv6 address information for their interfaces. interface/{interface-type}/{interface-name}/ipv6/nd/prefix Configures which IPv6 prefixes are included in IPv6 Neighbor Discovery Router Advertisement (RA) messages. interface/{interface-type}/{interface-name}/ipv6/nd/ra-interval Configures the maximum interval range and minimum interval at which IPv6 Neighbor Discovery Router Advertisement (RA) messages are sent. interface/{interface-type}/{interface-name}/ipv6/nd/ra-lifetime Configures the amount of time in IPv6 Neighbor Discovery that a router is considered a valid default router. interface/{interface-type}/{interface-name}/ipv6/nd/reachable-time Configures the amount of time in IPv6 Neighbor Discovery that a device considers a remove IPv6 node reachable. interface/{interface-type}/{interface-name}/ipv6/nd/retrans-timer Configures the time advertised between IPv6 Neighbor Discovery Neighbor Solicitation (NS) messages. interface/{interface-type}/{interface-name}/ipv6/nd/suppress-ra Disables the sending of ICMPv6 Router Advertisement (RA) messages, including those sent in response to a solicitation as well as MTUs. interface/{interface-type}/{interface-name}/ipv6/ra-dns-server Configures, modifies, or retrieves the Domain Name System (DNS) server address and the lifetime multiplier information to IPv6 hosts in the Router Advertisement (RA) message. interface/{interface-type}/{interface-name}/ra-dns-server/hoplimit Configures the number of hops to be advertised in IPv6 neighbor discovery router advertisement (RA) messages. interface/{interface-type}/{interface-name}/ra-dns-server/mtu Sets the size of the maximum transmission unit (MTU) that is advertised in Neighbor Discovery Router Advertisement (RA) messages. interface/{interface-type}/{interface-name}/ra-dns-server/other-config-flag In IPv6 Neighbor Discovery, indicates to hosts on a local link that they can use the stateful autoconfiguration feature to obtain configuration settings other than IPv6 address information for their interfaces. interface/{interface-type}/{interface-name}/ipv6/ra-domain-name Configures the domain name of the Domain Name System (DNS) suffix and the lifetime multiplier information to IPv6 hosts in the Router Advertisement (RA) message. interface/{interface-type}/{interface-name}/lldp/dcbx-version Specifies which version of the Data Center Bridging Exchange (DCBX) protocol to use. interface/{interface-type}/{interface-name}/lldp/disable Disables the Link Layer Discovery Protocol (LLDP) on the interface. interface/{interface-type}/{interface-name}/lldp/iscsi-priority Configures the priority that will be advertised in the DCBX iSCSI TLV for a specified interface. interface/{interface-type}/{interface-name}/lldp/profile Applies a Link Layer Discovery Protocol (LLDP) profile to an interface interface/{interface-type}/{interface-name}/isis/reverse-metric Configures the reverse metric value on a single IS-IS interface. interface/{interface-type}/{interface-name}/isis/priority Determines the priority of the interface for being elected as a designated IS. interface/{interface-type}/{interface-name}/isis/point-to-point Configures the network type for the IS-IS interface as point-to-point. interface/{interface-type}/{interface-name}/isis/passive Disables adjacency formation and advertisements on an IS-IS interface. interface/{interface-type}/{interface-name}/isis/ipv6-metric Configures the metric value for an interface under IPv6 IS-IS MT. interface/{interface-type}/{interface-name}/isis/ldp-sync Enables synchronization with IS-IS for an interface. interface/{interface-type}/{interface-name}/isis/hello-multiplier Specifies the number of IS-IS hello packets a neighbor must miss before a device declares adjacency as down. interface/{interface-type}/{interface-name}/isis/hello-interval Specifies how often an IS-IS interface sends hello messages to its IS-IS neighbors. interface/{interface-type}/{interface-name}/isis/hello-padding Re-enables IS-IS hello padding at the interface level. interface/{interface-type}/{interface-name}/isis/circuit-type Configures the type of adjacency used for an IS-IS interface. interface/{interface-type}/{interface-name}/isis/auth-mode Specifies the type of authentication used for an IS-IS interface. interface/{interface-type}/{interface-name}/isis/auth-key Configures an authentication key for a specified IS-IS interface. interface/{interface-type}/{interface-name}/isis/auth-check Enables authentication checking for an IS-IS interface. interface/{interface-type}/{interface-name}/link-oam-interface Configures the Link OAM protocol on an Ethernet interface. interface/{interface-type}/{interface-name}/link-oam/link-fault/action Sets action for a Link Fault event . interface/{interface-type}/{interface-name}/link-oam-interface/allow-loopback Enables or disables loopback. interface/{interface-type}/{interface-name}/qos/cos-mutation Enables applying a COS Mutation map to a physical interface. This command is supported for Ethernet and Port-Channel interfaces. interface/{interface-type}/{interface-name}/qos/trust/trust-dscp Enables trust DSCP for Switchport interfaces. This command is supported for Ethernet and Port-Channel interfaces. interface/{interface-type}/{interface-name}/qos/remark/remark-dscp Enables remark DSCP for Switchport interfaces. This command is supported for Ethernet and Port-Channel interfaces. interface/{interface-type}/{interface-name}/rmon/collection/history Collects Ethernet group statistics for later retrieval interface/{interface-type}/{interface-name}/rmon/collection/stats Collects Ethernet group statistics n a specific interface. interface/{interface-type}/{interface-name}/sflow/enable Enables sFlow on an interface. interface/{interface-type}/{interface-name}/sflow/polling-interval Configures the polling interval globally. interface/{interface-type}/{interface-name}/sflow/sample-rate Sets the default sampling rate for an interface. interface/{interface-type}/{interface-name}/spanning-tree/autoedge Enables automatic edge detection. interface/{interface-type}/{interface-name}/spanning-tree/bpdu-mac Sets the MAC address of the Bridge Protocol Data Unit (BPDU). interface/{interface-type}/{interface-name}/spanning-tree/cost Changes an interface's spanning-tree port path cost. interface/{interface-type}/{interface-name}/spanning-tree/edgeport Enables the edge port on an interface to allow the interface to quickly transition to the forwarding state. interface/{interface-type}/{interface-name}/spanning-tree/edgeport/bpdu-filter Sets the edge port Bridge Protocol Data Unit (BPDU) filter for the port. interface/{interface-type}/{interface-name}/spanning-tree/edgeport/bpdu-guard Guards the port against the reception of BPDUs. interface/{interface-type}/{interface-name}/spanning-tree/guard/root Enables the guard root to restrict which interface is allowed to be the spanning-tree root port or the path-to-the-root for the switch. interface/{interface-type}/{interface-name}/spanning-tree/hello-time Configures the hello-time in seconds on the interface. interface/{interface-type}/{interface-name}/spanning-tree/instance/priority Sets restrictions for the port of particular MSTP instances. interface/{interface-type}/{interface-name}/spanning-tree/instance/cost Configures the path-cost for a port. interface/{interface-type}/{interface-name}/spanning-tree/instance/restricted-role Specifies to restrict the role of a port. interface/{interface-type}/{interface-name}/spanning-tree/instance/restricted-tcn Specifies to restrict the propagation of the topology change notifications from a port. interface/{interface-type}/{interface-name}/spanning-tree/link-type Enables and disables the rapid transition for the Spanning Tree Protocol (STP). interface/{interface-type}/{interface-name}/spanning-tree/peer-switch When the Peer-Switch feature is enabled on a Cisco vPC domain, it broadcasts the same BPDUs from both vPC primary and secondary nodes to peer devices. But a VCS on a VLAG assumes that any logical interface receives only one BPDU from any of its member ports, so when it receives the two BPDUs from a Cisco vPC domain it creates a churn of VLAG mastership, and this increases the CPU load on a Extreme VDX. To avoid these problem, BDPUs received on the VLAG non-master are dropped. When the Peer-Switch functionality is enabled and the the VLAG Master is selected, BPDUs received on VLAG Non-Master are dropped unless there is a change in the status of the VLAG Master. interface/{interface-type}/{interface-name}/spanning-tree/portfast Enables the Port Fast feature on an interface to allow the interface to quickly transition to forwarding state. interface/{interface-type}/{interface-name}/spanning-tree/portfast/bpdu-filter Sets the Port Fast BPDU filter for the port. interface/{interface-type}/{interface-name}/spanning-tree/portfast/bpdu-guard Guards the port against the reception of BPDUs. interface/{interface-type}/{interface-name}/spanning-tree/priority Changes an interface's spanning-tree port priority. interface/{interface-type}/{interface-name}/spanning-tree/restricted-role Restricts the role of the port from becoming a root port. interface/{interface-type}/{interface-name}/spanning-tree/restricted-tcn Restricts the Topology Change Notification (TCN) Bridge Protocol Data Units (BPDUs) sent on the port. interface/{interface-type}/{interface-name}/spanning-tree/shutdown Disables spanning tree on the interface. interface/{interface-type}/{interface-name}/spanning-tree/vlan Configures the VLAN identifier for the spanning tree interface. interface/{interface-type}/{interface-name}/storm-control/ingress Limits ingress traffic on a specified interface. interface/{interface-type}/{interface-name}/switchport Puts the interface in Layer 2 mode and sets the switching characteristics of the Layer 2 interface. interface/{interface-type}/{interface-name}/switchport/access Sets the Layer 2 interface as access. interface/{interface-type}/{interface-name}/switchport/mode Sets the mode of the Layer 2 interface. interface/{interface-type}/{interface-name}/switchport/mode/private-vlan Sets the private VLAN (PVLAN) mode of the Layer 2 interface. interface/{interface-type}/{interface-name}/switchport/mode/trunk-no-default-native Configures a port to trunk mode without the implicit creation of default native VLAN 1 in a Virtual Fabrics context. interface/{interface-type}/{interface-name}/switchport/port-security Enables port security on an interface port. interface/{interface-type}/{interface-name}/switchport/port-security/mac-address Configures the MAC address option for port security on an interface port. interface/{interface-type}/{interface-name}/switchport/port-security/max Configures the maximum number of MAC addresses used for port security on an interface port. interface/{interface-type}/{interface-name}/switchport/port-security/oui Configures an Organizationally Unique Identifier (OUI) MAC address for port security on an interface port. All other addresses are ignored. interface/{interface-type}/{interface-name}/switchport/port-security/shutdown-time Configures the shutdown-time option for port security on an interface port. interface/{interface-type}/{interface-name}/switchport/port-security/sticky Converts dynamic MAC addresses to sticky secure MAC addresses. interface/{interface-type}/{interface-name}/switchport/port-security/violation Configures the violation response options for port security on an interface. ip/access-list/extended Configures extended IP access list. ip/access-list/extended/{acl-name}/seq Configures the sequence number. ip/access-list/standard Configures a standard IP access list. ip/access-list/standard/{acl-name}/seq Configures sequence number. ip/dhcp/relay/servers Configures DHCP relay servers. ip/route Configures IPv4 static routes. ipv6/access-list/extended Configure IPv6 extended access list. ipv6/access-list/extended/{acl-name}/seq Configures the sequence number. ipv6/access-list/standard Configures IPv6 standard access list. ipv6/access-list/standard/{acl-name}/seq Configures the sequence number. ipv6/route Configures the IPv6 static routes.lvtep/broadcast-local-bias Enables and disables broadcasting of local Broadcast, Unicast, and Multicast traffic over LVTEP. mac/access-list/extended/{acl-name}/seq Configures the sequence number mac/access-list/standard Configures standard MAC access-list. mac/access-list/standard/{acl-name}/seq Configures the sequence number. mac-address-table/aging-time Configures mac-address-table aging time. management-security next-hop-recursion Enables recursive next-hop resolution for PBR route-maps. ntp/authentication-key Configures NTP authentication key parameters. ntp/disable Disables the NTP server/client mode. ntp/master Configures the device as an authoritative NTP Server. ntp/peer Configures the NTP peers and specify the peers to synchronize the system clock. ntp/server Configures Network Time Protocol (NTP) server IP address. ntp/source-ip Configures the source IP to be used for Network Time Protocol (NTP). ntp/trusted-key configures additional subset of trusted key-IDs which can be used for NTP and client authentication. overlay-gateway Configures overlay gateway instances. overlay-gateway/{gateway-name}/activate Activates the Overlay Gateway instance. overlay-gateway/{gateway-name}/attach/vlan Configures VLAN attachment for this gateway. overlay-gateway/{gateway-name}/enable Enables per VLAN statistics. overlay-gateway/{gateway-name}/ip/access-group Configures IPv4 access-group for the Overlay Gateway. overlay-gateway/{gateway-name}/ip/interface/loopback Configures Loopback interface for the Overlay Gateway overlay-gateway/{gateway-name}/ip/interface/ve/{ve-id}/fabric-virtual-gateway Uses Fabric-Virtual-Gateway IP address. overlay-gateway/{gateway-name}/ip/interface/ve/{ve-id}/vrrp-extended-group Configures virtual router overlay-gateway/{gateway-name}/ipv6/access-group Configures IPv6 access-group for the Overlay Gateway. overlay-gateway/{gateway-name}/mac Configures MAC access-group for the Overlay Gateway. overlay-gateway/{gateway-name}/map Configures the VLAN to VNI mappings for the Overlay Gateway. overlay-gateway/{gateway-name}/monitor Configures SPAN for the tunnels of this gateway. overlay-gateway/{gateway-name}/sflow Configures SFLOW for the tunnels of this gateway. overlay-gateway/{gateway-name}/site Configures remote extension site. overlay-gateway/{gateway-name}/site/{site-name}/bfd Creates BFD session for the tunnels to the remote site. overlay-gateway/{gateway-name}/site/{site-name}/extend Configures Layer2 domains to be extended towards this site. overlay-gateway/{gateway-name}/site/{site-name}/ip Configures tunnel destination IP address. overlay-gateway/{gateway-name}/site/{site-name}/mac-learning/protocol/bgp By default, MAC address learning is enabled on VXLAN Layer 2 extension tunnels. Use this command to delegate the responsibility for MAC learning on a tunnel to the Layer 3 control-plane protocol, such as BGP EVPN. overlay-gateway/{gateway-name}/site/{site-name}/shutdown Disables tunnel to the remote site. overlay-gateway/{gateway-name}/type pecifies whether a VXLAN overlay gateway uses NSX Controller or OpenStack integration, or Layer 2 extension. password-attributes/expiry-alert-level Configures password expiry notification settings for user accounts. protocol/cfm Configures the CFM protocol. protocol/link-oam Configures the Link OAM protocol. protocol/lldp/advertise/dcbx-fcoe-app-tlv Enables IEEE data centre bridging exchange FCoE Application TLV. protocol/lldp/advertise/dcbx-fcoe-logical-link-tlv Enables IEEE data centre bridging exchange FCoE logical link TLV. protocol/lldp/advertise/dcbx-iscsi-app-tlv Enables IEEE data centre bridging exchange iSCSI application TLV. protocol/lldp/advertise/dcbx-tlv Enables IEEE data centre bridging exchange TLV. protocol/lldp/advertise/dot1-tlv Enables IEEE 802.1 organizationally specific TLV. protocol/lldp/advertise/dot3-tlv Enables IEEE 802.3 organizationally specific TLV. protocol/lldp/advertise/optional-tlv Enables the optional TLVs. protocol/lldp/description Configures user description for LLDP. protocol/lldp/disable Disable LLDP configuration. protocol/lldp/hello Configures the hello transmit interval. protocol/lldp/iscsi-priority Configures the Ethernet priority to advertise for iSCSI. protocol/lldp/mode Configures the LLDP mode. protocol/lldp/multiplier Configures the timeout multiplier. protocol/lldp/profile/{profile-name}/advertise Applies a Link Layer Discovery Protocol (LLDP) profile to an interface. protocol/lldp/profile/{profile-name}/hello Sets the interval between LLDP hello messages. protocol/lldp/profile/{profile-name}/mode Sets the LLDP mode on the switch. protocol/lldp/profile/{profile-name}/multiplier Sets the number of consecutive misses of hello messages before LLDP declares the neighbor as dead. protocol/lldp/system-description Configures the system description. protocol/lldp/system-name Configures the system name. protocol/spanning-tree/mstp/bridge-priority Configures bridge priority commands for multiple spanning tree protocol. protocol/spanning-tree/mstp/cisco-interoperability Configures Cisco interoperability. protocol/spanning-tree/mstp/description Configures spanning tree description. protocol/spanning-tree/mstp/error-disable-timeout/enable Enables timeout for the port to be enabled back. protocol/spanning-tree/mstp/error-disable-timeout/interval Configures time interval after which port will be enabled. protocol/spanning-tree/mstp/forward-delay Configures the forward delay time for the spanning tree. protocol/spanning-tree/mstp/hello-time Configures the hello time interval for the spanning tree. protocol/spanning-tree/mstp/instance/priority Configures bridge priority for the common instance. protocol/spanning-tree/mstp/instance/vlan Configures VLAN for MSTP. protocol/spanning-tree/mstp/max-age Configures the max age for the spanning tree. protocol/spanning-tree/mstp/max-hops Configures the maximum hops the BPDU will be valid for. protocol/spanning-tree/mstp/port-channel Controls port channel behavior for spanning tree protocol/spanning-tree/mstp/region Sets the MST region. protocol/spanning-tree/mstp/revision Sets the revision number. protocol/spanning-tree/mstp/shutdown Disables the Multiple Spanning Tree Protocol (MSTP) globally. protocol/spanning-tree/mstp/transmit-holdcount Configures transmit hold count of the bridge. protocol/spanning-tree/pvst/bridge-priority Configures bridge priority for PVST Spanning-tree. protocol/spanning-tree/pvst/description Configures the PVST spanning-tree description. protocol/spanning-tree/pvst/error-disable-timeout/enable Enables the timeout mechanism for the port to be enabled back. protocol/spanning-tree/pvst/error-disable-timeout/interval Configures interval after which port shall be enabled. protocol/spanning-tree/pvst/forward-delay Specifies the time an interface spends in each of the listening and learning states. protocol/spanning-tree/pvst/hello-time Sets the interval between the hello Bridge Protocol Data Units (BPDUs) sent on an interface. protocol/spanning-tree/pvst/max-age Sets the interval time in seconds between messages that the PVST spanning tree receives from the interface. protocol/spanning-tree/pvst/port-channel Sets the path-cost behavior. protocol/spanning-tree/pvst/shutdown Disables the Rapid Spanning Tree Protocol (RSTP) globally. protocol/spanning-tree/pvst/vlan/forward-delay Configures the forward-delay for PVST spanning tree protocol/spanning-tree/pvst/vlan/hello-time Configures the hello interval for the PVST spanning tree. protocol/spanning-tree/pvst/vlan/max-age Configures the max-age for the PVST spanning tree. protocol/spanning-tree/pvst/vlan/priority Configures the bridge priority. protocol/spanning-tree/rpvst/bridge-priority Specifies the bridge priority for the common instance. protocol/spanning-tree/rpvst/description Configures the RPVST Spanning tree description. protocol/spanning-tree/rpvst/error-disable-timeout/enable Enables the timer to bring the interface out of the error-disabled state. protocol/spanning-tree/rpvst/error-disable-timeout/interval Configures the timeout for errors on an interface. protocol/spanning-tree/rpvst/forward-delay Specifies the time an interface spends in each of the listening and learning states. protocol/spanning-tree/rpvst/hello-time Sets the interval between the hello Bridge Protocol Data Units (BPDUs) sent on an interface. protocol/spanning-tree/rpvst/max-age Sets the interval time in seconds between messages that the spanning tree receives from the interface. protocol/spanning-tree/rpvst/port-channel Sets the path-cost behavior. protocol/spanning-tree/rpvst/shutdown Disables the Rapid PVST(RPVST) globally. protocol/spanning-tree/rpvst/transmit-holdcount Configures the maximum number of Bridge Protocol Data Units (BPDUs) transmitted per second for the R-PVST+. protocol/spanning-tree/rpvst/vlan/forward-delay Configures the forward-delay for RPVST spanning tree. protocol/spanning-tree/rpvst/vlan/hello-time Configures the hello interval for the RPVST spanning tree. protocol/spanning-tree/rpvst/vlan/max-age Configures the max-age for the RPVST spanning tree. protocol/spanning-tree/rpvst/vlan/priority Configures the bridge priority. protocol/spanning-tree/rstp/bridge-priority Specifies the bridge priority for the common instance. protocol/spanning-tree/rstp/description Configures the Rapid Spanning tree (RSTP) description. protocol/spanning-tree/rstp/error-disable-timeout/enable Enables the timer to bring the interface out of the error-disabled state. protocol/spanning-tree/rstp/error-disable-timeout/interval Configures the timeout for errors on an interface. protocol/spanning-tree/rstp/forward-delay Specifies the time an interface spends in each of the listening and learning states. protocol/spanning-tree/rstp/hello-time Sets the interval between the hello Bridge Protocol Data Units (BPDUs) sent on an interface. protocol/spanning-tree/rstp/max-age Sets the interval time in seconds between messages that the spanning tree receives from the interface. protocol/spanning-tree/rstp/port-channel Sets the path-cost behavior. protocol/spanning-tree/rstp/shutdown Disables the Rapid Spanning Tree Protocol (RSTP) globally. protocol/spanning-tree/rstp/transmit-holdcount Configures the maximum number of Bridge Protocol Data Units (BPDUs) transmitted per second for the RSTP. protocol/spanning-tree/stp/bridge-priority Specifies the bridge priority for the common instance. protocol/spanning-tree/stp/description Configures the STP Spanning tree description. protocol/spanning-tree/stp/error-disable-timeout/enable Enables the timer to bring the interface out of the error-disabled state. protocol/spanning-tree/stp/error-disable-timeout/interval Configures the timeout for errors on an interface. protocol/spanning-tree/stp/forward-delay Specifies the time an interface spends in each of the listening and learning states. protocol/spanning-tree/stp/hello-time Sets the interval between the hello Bridge Protocol Data Units (BPDUs) sent on an interface. protocol/spanning-tree/stp/max-age Sets the interval time in seconds between messages that the spanning tree receives from the interface. protocol/spanning-tree/stp/port-channel Sets the path-cost behavior. protocol/spanning-tree/stp/shutdown Disables the STP Spanning Tree Protocol globally. qos-mpls Configures, retrieves, and modifies MPLS Quality of Service (QoS). qos/map/cos-mutation Creates and modifies a QoS CoS Mutation map. radius-server Configures a RADIUS server for AAA. ras Collects data for SupportSave. rbridge-lag/lag Configures the various Local Aggregation Group (LAG) settings. rbridge-lag/load-balance Configures the various Load Balancing Hash settings. rmon/alarm Configures Remote Monitoring Protocol (RMON) alarm. rmon/event Configures Remote Monitoring Protocol (RMON) event. /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/additional-paths/activate Activates the inheritance of additional-paths capability from the address family for a specific peer in a BGP address family. /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/additional-paths/advertise /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/allowas-in /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/capability Advertises Outbound Route Filter (ORF) capabilities to peer routers. You can configure this capability for TX, RX, or Both directions. /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/additional-paths/disable Deactivates the inheritance of additional-paths capability from the address family for a specific peer in a BGP address family. /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/default-originate Configures the BGP device to send the default route ::/0 to a BGP neighbor and also provide the Route Map that can be applied to any default-originated route. /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/enable-peer-as-check Enables the outbound AS_PATH check function to prevent a sending BGP peer from sharing routes with an AS path that contains the AS number of the receiving BGP peer. /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/filter-list Specifies a filter list to be applied to updates received from or sent to the specified BGP peer. /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/maximum-prefix Configures the maximum number of IP routes that can be learned from the specified neighbor. /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/prefix-list Filters outgoing and incoming route updates to/from a particular BGP neighbor using the IP address and mask length defined in an assigned prefix-list. /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/route-map /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/route-reflector-client Configures a BGP Peer as a route reflector client. /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/send-community Sends the community attribute in updates to the specified BGP neighbor. /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/additional-paths/txrx /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/unsuppress-map Removes route suppression from BGP neighbor routes when those routes have been suppressed because of aggregation. All routes matching the entries in the route map are unsuppressed. /router/bgp/address-family/ipv6/unicast/{vrf-name}/neighbor/{ipv4-neighbor-address}/weight Specifies a weight that the device will add to routes that are received from the specified BGP neighbor. BGP prefers routes with higher ranks. /router/bgp/address-family/l2vpn/evpn/import/vpnv4/unicast/uniform-path-propagation Preserve source path attributes of L3VPN v4 routes when they are propagated to EVPN VxLAN peers. /router/bgp/address-family/vpnv4/unicast/import/l2vpn/evpn/uniform-path-propagate Preserve source path attributes in EVPN routes when these routes are propagated over VPNv4 session. /router/bgp/neighbor/neighbor-peer-grp/{peer-group}/update-source Updates the update-source IPv4 and IPv6 address for BGP peer groups. /router/bgp/peer-group/ipv6prefix-over-ipv4peer Enables the exchange of IPv6 routes with BGP neighbors over IPv4 session. This configuration only applies to those BGP neighbors that are members of a peer-group.interface/{interface-type}/{interface-name}/isis Configures the IS-IS protocol. router/isis/is-type Changes the IS-IS level globally. route-map Configures, retrieves, and modifies route-map instance. router/mpls Configures the MPLS protocol. router/mpls/ldp Configures the Label Distribution Protocol (LDP). router/mpls/lsp Configures the various label-switched path (LSP) parameters. router/mpls/rsvp Configures the MPLS RSVP. router/mpls/policy Configures an MPLS policy. router/mpls/policy/transit-session-accounting Enables traffic statistics for transit sessions. router/mpls/policy/ingress-tunnel-accounting Enables traffic statistics for tunnel interfaces. router/mpls/policy/qos-ttl-mode Configures the MPLS TTL and QOS propagation model. router/mpls/policy/traffic-engineering/isis Defines timer value for soft preemption to happen. router/mpls/policy/soft-preemption/cleanup-timer Defines timer value for soft preemption to happen. router/mpls/policy/cspf-computation-mode/rsvp-periodic-flooding-time Sets the interval for RSVP TE periodic flooding. router/mpls/policy/cspf-computation-mode/rapid-retry Configures the rapid retry option. router/mpls/policy/cspf-computation-mode/retry-time Configures LSP retry time. router/mpls/policy/cspf-computation-mode/handle-ospf-neighbor-down Configures MPLS to handle OSPF neighbor down event. router/mpls/policy/cspf-computation-mode/handle-isis-neighbor-down Configures MPLS to handle ISIS neighbor down event. router/mpls/policy/cspf-computation-mode/cspf-interface-constraint Uses interface IP address for Constrained Shortest Path First (CSPF) computation. router/mpls/policy/cspf-computation-mode/add-penalty Adds penalty of all matching Constrained Shortest Path First (CSPF)-groups to TE metric of TE link. router/mpls/policy/cspf-computation-mode/metric-type Selects metric type for CSPF computation.. router/mpls/policy/cspf-computation-mode/ignore-overload-bit Ignores overload bit during CSPF computation. router/mpls/policy/backup-retry-time Configures the backup retry time. router/mpls/cspf-group/(cspf-groupname)/penalty Configures the CSPF group penalty value. router/mpls/lsp-xc-traps/enable Enables the LSP cross connect up, down, logging, and traps. router/mpls/rsvp/reliable-messaging/rapid-retry-limit Configures the maximum number of retries for an unacknowledged message. router/mpls/rsvp/reliable-messaging/rapid-retrans-interval Configures an interval for an unacknowledged message to be resent. router/mpls/rsvp/reliable-messaging/rapid-retrans-decay Percentage increase in the rapid retransmission interval for each consecutive unacknowledged RSVP message. router/mpls/rsvp/refresh-reduction/bundle-message/bundle-send-delay Configure the bundle send delay value. router/mpls/rsvp/refresh-multiple Configures the MPLS RSVP refresh multiple. router/mpls/rsvp/refresh-interval Configures the MPLS RSVP refresh interval. router/mpls/rsvp/g-rsvp-backup-bw-guarantee Sets up a backup path requesting bandwidth. router/mpls/rsvp/global-rsvp-hello-acknowledgements Acknowledges the RSVP hellos on interfaces supporting RSVP hello and not having RSVP sessions. router/mpls/rsvp/global-rsvp-hello/tolerance Configures the number of unacknowledged RSVP hello requests before timeout. router/mpls/rsvp/global-rsvp-hello Configures the interval between two RSVP hello requests. router/mpls/rsvp/refresh-reduction/summary-refresh Configures the refresh reduction summary refresh feature. routing-system/ip/dhcp/relay/disable-flooding Configures disabling flooding of IPv4 DHCP Relay packets. show/selinux/status Displays the current SE Linux configuration for this SLX-OS device. sflow/agent-address Configures the sFlow agent-ID address.. sflow/collector Configures sFlow collector. sflow/enable Enables sFlow globally. sflow/polling-interval Configures interface counter polling interval. sflow/sample-rate Configures interface sampling rate. sflow/source-ip Configures source IP address to use. sflow/update-destination-mac Updates the destination MAC address in the sFlow sample for routed packets. sflow-profile Configures sflow profile sampling rate. snmp-server/use-vrf/{vrf-name} Starts or stops SNMP service on the specified VRF.show-grub-version Displays the current grub version for this SLX-OS device. show-onie-version Displays the current onie version for this SLX-OS device. snmp-server/trap/bfd-std-mib Configures Standard MIB for BFD Traps.snmp-server/use-vrf/shutdown Shuts down a user defined VRF. system-monitor Configures, modifies, or retrieves FRU threshold and alert setting. system-monitor-mail/fru (email) Configures e-mail address for FRU alerts. system-monitor-mail/fru/enable Enables FRU e-mail alerts. system-monitor-mail/interface (email) Configures e-mail address for interface alerts. system-monitor-mail/interface/enable Enables interface e-mail alerts. system-monitor-mail/relay Configures relay IP mail settings. system-monitor-mail/security (email) Configures e-mail address for security alerts. system-monitor-mail/security/enable Enables security e-mail alerts. system-monitor-mail/sfp (email) Configures e-mail address for SFP alerts. system-monitor-mail/sfp/enable Enables sfp e-mail alerts. system-watermark Defines system-related information. topology-group Configures topology VLAN group for L2 protocols. vlan/{vlan-name}/mac Configures a MAC access group. vlan/classifier/group Configures VLAN classification group commands. vlan/classifier/rule/mac Configures VLAN classification rule commands. vlan/classifier/rule/proto Configures the protocol to use for the VLAN classifier rule. vlan/dot1q Configures dot1q parameters. vrf Configures the virtual rounding and forwarding (VRF). vrf/{vrf-name}/address-family/ipv4/unicast Configures the IPv4 address family configurations. vrf/{vrf-name}/address-family/ipv4/unicast/max-route Configures IPv4 address family maximum route. vrf/{vrf-name}/address-family/ipv6/unicast Configures the IPv6 address family configurations. vrf/{vrf-name}/address-family/ipv6/unicast/max-route Configures IPv6 address family maximum route. vrf/{vrf-name}/ip/router-id Configures the IP route details.. vxlan-visibility Configures an overlay transit.
