Firewall Requirements
Connection to the following domains is required during installation and upgrades so that Universal Compute Platform can download the appropriate packages.
Table 1. Required Connection Domains for Installs and Upgrades
Domain NameIP AdressesProtocolPort
docker.ioDynamic IP rangeHTTPS443
gcr.ioDynamic IP rangeHTTPS443
ghcr.ioDynamic IP rangeHTTPS443
quay.ioDynamic IP rangeHTTPS443
registry.k8s.ioDynamic IP rangeHTTPS443
Internet connectivity is required in these situations:
Once the stand-alone cluster is created, internet connectivity is not required while installing, upgrading, or running application engines that run on the appliance (unless the specific application engine requires it, or unless you onboarded to the cloud).
If the appliance is to be deployed as an air gap use case, the initial configuration of the host needs to take place in a staging location where internet services are available (for example, DNS, NTP and Docker access). Once the node is initialized to support the target application, the appliance can be moved to its target location.
The following connections are required if you connect to ExtremeCloud IQ.
Table 2. Required Connections for Cloud Deployments
Domain NameIP AddressesProtocolPortDescription
hac.extremecloudiq.com34.253.190.192 ~ 34.253.190.255HTTPS443Onboarding to ExtremeCloud IQ
<rdc>-inlets.extremecloudiq.comDynamic IP rangeTCP8090Ongoing connection to ExtremeCloud IQ
