Supported Hardware for Self-Orchestration
ExtremeCloud Edge - Self-Orchestration deployments of Universal Compute Platform support the following hardware appliances. Depending on the hardware, you may be able to install more than one instance of an application on a node.
Table 1. Supported Hardware for ExtremeCloud Edge - Self-Orchestration
Hardware ApplianceDetails
1130C
Ports:
  • 2 x 1 Gbps ICC Ports/RJ45
  • 4 x 1 Gbps Data 1-4/RJ45
Self-Orchestration deployment application capacity:
  • Tunnel Concentrator—One instance per node
  • ExtremeCloud IQ Controller (CE1000)—One instance per node
For additional server specifications, along with hardware installation information, see Extreme Networks Universal Compute Platform Appliance 1130C Installation Guide.
2130C
Ports:
  • 2 x 1/10 Gbps ICC Ports/RJ45
  • 2 x 10 Gbps Data Ports 1-2/SFP28
  • 2 x 10/25 Gbps Data Ports 3-4/SFP28
  • ExtremeCloud IQ Controller (CE2000)—One instance per node
  • ExtremeCloud IQ - Site Engine—One instance per node
  • ExtremeControl—One instance per node
  • ExtremeAnalytics—One instance per node
For additional server specifications, along with hardware installation information, see Extreme Networks Universal Compute Platform Appliance 2130C Installation Guide.
3150C
Ports:
  • 2 x 10/25 Gbps Data Ports 1-2/SFP28
  • 2 x 10/25/50/100 Gbps Data Ports 3-4/QSFP28
  • ExtremeCloud IQ Controller (CE3000)—One instance per node
  • ExtremeWireless WiNG Controller (CX9000)—One instance per node
For additional server specifications, along with hardware installation information, see Extreme Networks Universal Compute Platform Appliance 3150C Installation Guide
4120C/4120C-1
Ports:
  • 2 x 1/10 Gbps Data 1-2/RJ45
  • 2 x 1/10/25/40/50 Gbps Data 3-4/QSFP
  • Tunnel Concentrator—Up to three instances per node.
For additional server specifications, along with hardware install information, see Extreme Networks Universal Compute Platform Appliance 4120C Installation Guide.
Support is for a single application type per node. Application mixing on a single appliance is not supported.
