LLDP and CDP Settings
Table 1. Settings for LLDP and CDP
SettingDescription
NameType a Name for the new LLDP/CDP object.
Description(Optional)
Type a Description for the new LLDP/CDP object. Although optional, entering a description is helpful for troubleshooting and for identifying the LLDP/CDP object.
Enable LLDP on access portsSelect the check box to permit LLDP on access ports.
Note: LLDP is enabled on other port types by default.
Enable receive only mode.Select the check box to permit devices to receive, cache, and display LLDP advertisements from other devices, but to not advertise their own data.
LLDP entries to cache(IQ Engine Only)
Type the maximum number of LLDP entries from neighboring network devices that a device can store in its cache.
Neighbors keep Extreme Networks advertisements forType the number of seconds for which neighboring devices retain LLDP advertisements.
Increase the time while troubleshooting a network issue and decrease it if you need to reduce overall network traffic.
Advertisements IntervalType the number of seconds between LLDP advertisements sent to neighboring network devices.
Timer HoldType a multiple of the advertisements interval. (EXOS/Switch Engine, VOSS/Fabric Engine, SR22XX/23XX, Dell)
Max power for LLDP advertisementsSelect Use the default max power in IQ Engine to use the maximum power level that devices can request in LLDP advertisements.
LLDP Initialization Delay TimeType the length of time that you want the interface to wait before initializing LLDP.
Fast start repeat countType the number of advertisement LLDP frames to send when the connected device (such as an IP phone) starts up or is detected.
CDP (Cisco Discovery Protocol)Toggle CDP ON to enable devices to receive and cache CDP advertisements.
Note: You can enable LLDP and CDP concurrently.
CDP is a proprietary Data Link Layer protocol developed by Cisco Systems.
Enable CDP on access ports.Select the check box to permit CDP on access ports.
By default, CDP is enabled on other port types.
CDP entries to cacheType the maximum number of CDP entries that a device can store in its cache.
