Generate Activation License
All customers must generate and install an activation license. After you install the CE deployment, use this procedure to generate and install the activation package.
  1. Obtain the Locking ID of the CE instance:
    1. Log in to the CE instance.
    2. Under Upload Activation License , copy the Serial Number (Locking ID) value.
    If you plan to onboard to ExtremeCloud IQ, copy the MAC Address value too as you will need it during cloud onboarding.
  2. Obtain the activation file:
    1. Log in to the Extreme Networks Support Portal .
    2. Go to Assets > Licenses Home and select the CE1000, CE2000, or CE3000 Voucher ID line item from the list.
    3. On the Voucher Details page, select Generate Activation Key .
    4. Provide the serial number for the CE activation.
    5. Select the box to accept Terms and Conditions and select Submit to generate the activation file.
    6. Download the activation file.
  3. Install the activation file:
    1. If you signed out of CE container, sign back in.
    2. Upload the license file to the Upload Activation License pane.
