Access points and switches are automatically added to ExtremeCloud IQ Controller via the cloud-connector when the DHCP and DNS prerequisites have been met. For full instructions on configuring DHCP, NPS, and DNS services, refer to the ExtremeCloud IQ Controller Deployment Guide. You can use the Add functionality to pre-provision any AP or switch before they connect.
Using the Add functionality, you can clone an existing AP or add a unique AP configuration.
Tip
If your APs are not displaying within the Edit Device Group page, verify the following:
You can add several APs and then register them at one time. An AP that is discovered by ExtremeCloud IQ Controller, but is not yet a member of a device group, has a status of In-Service Trouble.2120W-2123400000 (16 digits).64002103260092 (14 digits).640021032-60092 (15 digits)
Most AP radio properties depend on a regulatory domain; which is defined at the site level. Devices that are connected to ExtremeCloud IQ Controller but not assigned to a device group have the status of In-Service Trouble. Devices that have not discovered ExtremeCloud IQ Controller have the status of Unknown.
