Settings for WPA3–Enterprise (802.1X/EAP)
WPA3–Enterprise (802.1X/EAP) — Requires Protected Management Frames (PMF) enabled. For a network with WPA3–Enterprise (802.1X/EAP) authentication, PMF cannot be disabled. Network access is allowed to any client that knows the pre-shared key (PSK).
6E WPA Compliance (WPA3)
Configure the following privacy settings:
  • Fast Transition — Provides faster roaming by authenticating the device before roaming occurs. This setting is enabled by default.
    Fast Transition and Multi-Link Operation (MLO) are incompatible. Disable Fast Transition then enable MLO on the network to use WPA3–Enterprise (802.1X/EAP) authentication.
  • Mobility Domain ID — Used by 802.11r, this setting defines a network scope that supports 11r fast roaming. Master keys are shared within the Mobility Domain, allowing clients to support fast roaming.
ExtremeCloud IQ Controller also supports WPA3-Enterprise with 192-bit mode.
