On AP models that include a dedicated sensor radio, you can use Smart RF AutoSensor Placement to automate sensor radio assignment across a site. When AutoSensor Placement is enabled in the Smart RF policy, ExtremeCloud IQ Controller dynamically selects which APs activate their dedicated sensor radio, targeting one sensor AP for every three data APs. The controller recalculates sensor selection hourly based on current AP density.
AutoSensor Placement is the recommended method for managing sensor deployment in large campus environments where manually configuring individual AP sensor radios is not practical. For configuration details, see Smart RF Auto Sensor Settings.
For deployments that require static sensor assignment—for example, where specific APs must remain dedicated sensors regardless of density—configure the sensor radio manually using the procedures described in this topic.
In sensor mode, the radio does not service clients. The radio changes channels and functions as a sensor for AirDefense Essentials service or ADSP and Positioning services. Positioning can co-exist with any radio mode. The access point (AP) scans all channels that are allowed by the selected country. When the configuration Profile includes an ADSP profile, the ADSP server controls the channels, and Positioning reports the MAC addresses and RSS values that the radio receives.
ADSP is supported on all Extreme Wireless APs.
The method you use to configure an AP radio as a sensor depends on the AP model.
For AP4020/X/FX, AP4060/X, AP5020, AP5022/FX/SD6, and AP5060D/U, consider the following:
For AP4020/X/FX, AP4060/X, AP5020, AP5022/FX/SD6, and AP5060D/U models, to enable the Radio 4 sensor:
For all other eligible AP models, from the Edit Profile page, select the Radios tab. Set the Mode to Sensor, as follows:
After the radio mode is set to Sensor on the configuration Profile, define the scan list under Advanced Profile settings.
