The following conditions must be met before you perform this procedure:
Use this procedure to configure Auto Sensor settings.
You can invoke the Smart RF Auto Sensor feature on eligible AP models either manually or automatically. You can choose the band over which the Neighbor Report collects its data. When the feature is invoked, ExtremeCloud IQ Controller automatically selects and manages sensor APs based on deployment density, with the goal of achieving a ratio of one sensor AP for every three data APs.
| Parameter | Description |
| Algorithm | Choose the algorithm that best represents the selected device group deployment type. Options are:
| Band | Select the band over which the neighbor report is to be collected. Options are:
| Trigger | Choose how the Auto Sensor is to be invoked. Options are:
When enabled, ExtremeCloud IQ Controller automatically selects one AP to operate as a sensor for every three data APs in the site. The controller recalculates sensor selection hourly.
When disabled, sensor radios on eligible APs are not automatically activated by the Smart RF policy. Sensor mode can still be configured manually. See Radio as a Sensor.
ExtremeCloud IQ Controller calculates sensor placement for the site based on current AP density. The initial sensor selection occurs within the first hourly recalculation cycle after the policy is saved. Selected sensor APs activate their dedicated sensor radio, which begins reporting wireless data to the configured ADSP server.
To verify which APs are currently acting as sensors, view the Auto Sensor status on the Site Monitoring page.
To disable Auto Sensor on a specific AP without disabling the feature for the entire device group, use the Advanced > Overrides dialog for the selected AP.
