Subgraph Statistics
Go to , then select a floor plan under the Floor column to view subgraphs built within the boundaries of the floor plan. Next, select a graph under the Subgraph column to view related statistics.
The Subgraph Statistics display is divided into three panels:
All APs
Anchor APs
AP-to-AP Ranging
All APs
Following is a description of the information displayed under each column heading in the All APs panel.
- AP Name — Unique name assigned to the AP
- Set Time — Time at which the AP derived its geo coordinates from the Geo-Location Agent or GPS
- Latitude — Latitude as derived from the Geo-Location Agent or GPS
- Longitude — Longitude as derived from the Geo-Location Agent or GPS
- Circular Error [m] — R95 measure (in meters) of the accuracy of a GPS receiver. For example, a Circular Error of 60 meters means that 95% of the time, the GPS position is within 60 meters of the true GPS location.
- Height [m] — Height (in meters) at which the AP is installed above floor level
- Anchor Type — Source from which the AP derived geo coordinates
- FTM Ranges — Number of FTM-detected APs that are within range of the selected AP
Anchor APs
Following is a description of the information displayed under each column heading in the Anchor APs panel.
- Status — Available or Unavailable
- Circular Error[m] — R95 measure (in meters) of the accuracy of a GPS receiver. For example, a Circular Error of 60 meters means that 95% of the time, the GPS position is within 60 meters of the true GPS location.
- Source — GPS coordinates derived from third-party APP or integral GPS module.
- Set Time — Time at which the AP derived its geo coordinates from the Geo-Location Agent or integral GPS
AP-to-AP Ranging
Following is a description of the information displayed under each column heading in the AP-to-AP Ranging panel.
- Initiator — Unique name of an AP designated as initiator of FTM AP-to-AP ranging. An AP is designated as initiator when it ranks among the top 10 APs in the neighbor list with the highest RSSI value. Only neighboring APs that advertise a matching floor number of the initiator are considered in AP-to-AP ranging operations.
- Responder — Unique name of an AP configured as responder in FTM AP-to-AP ranging operations. All indoor APs placed on AFC floor plans must adopt a profile that has FTM (11mc) responder support enabled. See Advanced Network Settings for details.
- Distance — Distance between Initiator and Responder
- Set Time — Time at which the distance measurement is recorded
- Band — Band over which AP-to-AP ranging occurs
- Channel Width[MHz] — Channel and channel width used by the initiator or responder, as applicable
