Sensor mode converts the radio to a sensor for ADSP and Positioning. The AP4xx access point models offer a third radio that is a separate sensor radio, and AP4020/X/FX, AP4060/X, AP5022/FX/S6D, and AP5060D/U offer a fourth radio that is a dedicated sensor. For more information, see Radio as a Sensor.
Only one radio can be configured for Client Bridge. All traffic received by the client bridge AP over wired port or by the remaining radios is forwarded to the infrastructure network via the client bridge radio.| AP Model | Radio 1 | Radio 2 | Radio 3 |
| AP302W | 2.4GHz /5GHz (dual
band)
5GHz
Note: 160 MHz channel width not
supported.
| AP305C/CX | 2.4GHz /5GHz (dual band)
5GHz
Note: 160 MHz channel width not supported.
AP305C must configure sensor for both radios together. |
Note: AP305C/CX offers a
single port. When Client Bridge is configured on a single interface AP, the single
interface is used as the client port, not as an uplink, and you will not see the
ETH1 Port Function field in the Profile
Advanced dialog.
The Bridge port is not supported on access points with a
single Ethernet port.
5GHz
supported.
| AP360i/e | 2.4GHz /5GHz (dual band)
5GHz
supported.
| AP3000/X | 2.4GHz
/6GHz (dual band)
5GHz
| AP3020W 1 |
2.4 GHz
6 GHz
5 GHz
2.4GHz
5GHz
6GHz/Sensor
AP4020/X/FX 1 |
2.4GHz
5GHz
6GHz
AP4060/X |
2.4GHz
5GHz
6GHz
2.4GHz
5GHz
Sensor
2.4GHz /5GHz
5GHz
Sensor
| AP460e | 2.4GHz
5GHz
Sensor
| AP460C/S6C/S12C | 2.4GHz/ 5GHz
5GHz
Sensor
| AP5010 | 2.4GHz/
Tri-band Sensor, supports 2.4GHz wireless service, or a tri-band
sensor
5GHz
6GHz
AP5020 |
2.4 GHz
Tri-band Sensor
5 GHz L
6 GHz L
5 GHz
5 GHz H
2.4 GHz
6 GHz
6 GHz H
AP5022/FX/SD6 |
2.4GHz
5GHz L
6GHz H
5GHz
5GHz H
6GHz
6GHz L
AP5050D/U |
2.4GHz/
sensor
5GHz
6GHz (Not currently supported for
regulatory compliance)
AP5060D/U |
2.4GHz
5GHz L
6GHz H
5GHz
5GHz H
6GHz
6GHz L
| AP505i | 2.4GHz
5GHz
5GHz
| AP560i/h | 2.4GHz /5GHz (dual band)
5GHz
| AP39xx | 5GHz
2.4GHz
The Protocol/Role options available for each AP3020W, AP4020/X/FX, AP4060/X, AP5020, AP5022/FX/SD6, and AP5060D/U radio depends on the selected Operational Mode.
