Installation Prerequisites
Before you install Tunnel Concentrator, make sure that you meet the following requirements:
Licensing and Activation Prerequisites
Complete the following install and license requirements on the Extreme Networks Support Portal:
  • Purchase the Tunnel Concentrator activation SKU EXTR-IQ-TC.
  • Download the Tunnel Concentrator installation image from the portal at Downloads/ExtremeCloud/Extreme Tunnel Concentrator.
Universal Compute Platform Prerequisites
Install and connect the hardware appliance. Refer to the Installation Guide model for your selected model:
  • 1130C
  • 2130C
  • 3150C
  • 4120C
ExtremeCloud IQ Prerequisites
If you choose to deploy ExtremeCloud IQ as the management application, note the following:
ExtremeCloud IQ Controller Prerequisites
If you choose to deploy ExtremeCloud IQ Controller, note the following:
Reserved IP Ranges
The following table displays the reserved IP addressing ranges for use with Tunnel Concentrator.
Table 1. Reserved IP Ranges
PurposeIP RangeDetails
Tunnel Concentrator Application Network10.0.2.0/24This range is non-configurable. The range forms the attachment point for management access to the Tunnel Concentrator application.
Pod Network The Pod segment that you assigned on the host (the default range is 10.96.0.0/16)This is the segment range for the Pod Network that was assigned on Universal Compute Platform during host cluster creation. Please review cluster configuration on host to confirm.
