The left-panel tree includes your networks. Expand your networks to display the locations within each network. Select a location. Then select widgets in the Main panel to display the client and usage data for the selected locations.
Filter data or change the view of a widget using the controls available on the dashboard. Not all controls are available for each widget. The following table describes the widget controls:
| Dashboard Control | Location | Description |
| Top-right corner of the dashboard | Select to enable the |
| Top-right corner of the dashboard | Select to refresh the dashboard data. | |
| Top-right corner of the dashboard | Select to add, edit or remove widgets from the dashboard. | |
| Top-right corner of the dashboard | Select to remove widgets from the dashboard. | |
| Top-right corner of the widget | Select to maximize and minimize a widget respectively. |
