Upgradeable to Core
Upgradeable to Core
| Software Feature | Supported Platforms |
AVB
All Advanced Edge platforms. The X695 series switches have the AVB Feature License included in the Advanced Edge or Base License. You do not need to separately purchase and install the AVB Feature License for these switches. |
| BGP Auto-peering | X465, X695 |
| EAPS Advanced Edge—multiple physical rings, and "common links", also known as "shared port". | All Advanced Edge platforms |
| ERPS-more domains (allows 32 rings with matching ring ports) and multi-ring support | All Advanced Edge platforms |
| ESRP-Full | All Advanced Edge platforms |
| ESRP-Virtual MAC | All Advanced Edge platforms |
| OSPFv2-Edge (limited to max of 4 active interfaces) | All Advanced Edge platforms |
| OSPFv2 Auto-peering | X465, X695 |
| OSPFv3-Edge (limited to max of 4 active interfaces) | All Advanced Edge platforms |
| PIM-SM-Edge | All Advanced Edge platforms |
| PSTag | X465, X695 |
| VRRP | All Advanced Edge platforms |
| VXLAN | X465, X695 |
